Experiencing Power-steering Issue with my G35
Old Nov 8, 2017 | 02:23 PM
  #31
MR.BOJANGLES's Avatar
The easy way of spraying the steering column lower U joint.
1. Turn your wheels all the way to the left.
2. Looking through the gap you should be able to see the U joint at the end of the steering column.
Link to what you are looking for:
https://parts.endrasinfiniti.ca/p/In...8080AG30A.html
3. Have one person spray the U joint while another moving the steering wheel left and right to evenly spread the lubricant.
Old Nov 8, 2017 | 02:42 PM
  #32
Urbanengineer's Avatar
You can see it through the left wheel well with the wheel off pretty easily.
Old Nov 8, 2017 | 10:26 PM
  #33
coffeysm's Avatar
I just had this joint replace a few weeks ago. It was about 150 bucks at the dealer. You might be able to free it up by hitting it with a hammer, but it will freeze again. I had my mechanic do it for about 2 hours of labor charge. Car steers like new now. Definitely diagnose it though before you start replacing parts. Mine was completely rusted up.
Old Nov 8, 2017 | 11:18 PM
  #34
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's one of those pieces that I'm shocked manufacturers don't protect better, a rubber boots around it would prevent nearly all wear and tear yet you never see them covered.
Old Nov 8, 2017 | 11:54 PM
  #35
coffeysm's Avatar
I know, but it did take 11 years for mine to finally seize up on me, lol. It was amazing though how that tiny u-joint made my car almost impossible to turn.
Old Jul 11, 2019 | 01:52 PM
  #36
cadman777's Avatar
G35 Base w/some aftermarket performance add-ons
Mark,
Thanx for the tip: 'Steering column-to-rack u-joint binding up.'
I PB Blasted it, worked it a bit, then lubed it, and it loosened up enough to be good for a while.
Your proven results is what I always look for in these forums.
Incidentally, I was helping my neighbor w/his G35, so you helped me to help him.
Thanx!
Old Oct 24, 2019 | 04:48 PM
  #37
ProjectG35x's Avatar
G35x Premium Package
Did you guys just buy and replace the u joint? Or did you have to buy the entire lower steering column?
The reason I am asking is because the stock driveshaft's u joint can't be removed like an aftermarket. Curious about the lower steering column u joint as well.
https://www.infinitipartsdeal.com/pa..._column,,48080
Old Oct 24, 2019 | 05:56 PM
  #38
cadman777's Avatar
We didn't change anything.
We put the front of the car on jack stands, removed the driver's side wheel, and then I got a can of PB Blaster and sprayed it on the u-joint bearings while my neighbor rotated the steering wheel in both directions until it began loosening up. Then I got some good quality motor oil (Mobile 1) and squirted it into the u-joint bearings until I was satisfied it absorbed the oil.
My neighbor drove it around the block and told me it was as good as new.
If the joint was very loose after that I would have changed it, but we didn't have to.
Cost: a few pennies + 15 minutes of 'work'.
Good luck!
Old Oct 24, 2019 | 08:28 PM
  #39
cleric670's Avatar
BANNED!!!
The u-joint has a slip fitting where it clamps over the steering shaft, you don't replace the upper shaft.
Old Jul 9, 2024 | 12:32 AM
  #40
QX1's Avatar
QX1
Originally Posted by Eno
Assuming fluid levels are normal?
can it be over max level?
adam_g35x
V36 Brakes, Suspension, Wheels & Tires
Feb 27, 2020 12:16 AM
SiouxFallsG35
Drivetrain
Oct 6, 2018 11:28 AM
Imran Ahmed
May 27, 2018 12:12 AM
Sonyboys77
Oct 19, 2011 09:54 PM
