oil leak from rear
Old 03-29-2013, 03:40 AM
Ednica87's Avatar
oil leak from rear
noticed oil/liquid leaking from where the drive shaft connects to rear differential? 88k how would you stop leak?
Posted from G35driver.com App for Android
Old 03-29-2013, 11:29 AM
OBsessed's Avatar
Probably need to have the rear differential seal replaced. It's a bit of a pain in the ***. You can check YouTube for an idea of what it'll generally take to give you an idea of whether or not you want to tackle it yourself.
I don't know why it would become a problem at 88k though. It might be worth having it checked out by a pro as it could be a symptom of something larger going on. Seals will go out over time, but I wouldn't expect it to happen that soon in the car's lifespan.
Old 03-29-2013, 11:38 AM
herrschaft's Avatar
Are you sure its not coming from behind the diff? Check the rubber hose attached to the top of the diff and see where the end of it is. If its leaking from around the flange than the seal inside the front part needs to get replaced. Normally those seals don't go bad though.
Old 04-02-2013, 03:54 PM
Ednica87's Avatar
Thanks I noticed the leak on the ground and really didn't have a good chance to pin point the exact location, just from what I could tell w/o raising the car. Infiniti dealer told me I should be replaced at 90k though. Cuz I asked what is recommended for mileage service.
Old 04-02-2013, 08:49 PM
herrschaft's Avatar
There are two possibilities for the fluid.
1) The rear mounting point for the diff is in the subframe, the bushing at that point is filled with fluid and will leak when it goes bad. Its the round black thing:
2) There's also a rubber hosed attached to the top of the diff on the right side, its essentially there for overflow. So if someone put too much fluid in the diff it would definitely be coming out of that hose. Its a short hose so the end of it is easy to find because it doesn't go to anything.
More than likely the front seal where it connects to the driveshaft is not leaking.
Old 04-03-2013, 02:56 AM
Ednica87's Avatar
Thanks am I looking at a coupe sub frame? I'm assuming its the same? Thanks I'll check it out this weekend and see where its coming from.
Old 04-03-2013, 03:11 AM
herrschaft's Avatar
^The diff and the bushing are the same regardless.
Old 04-03-2013, 07:13 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
My guess it's the bushing, that's a common issue as our cars approach 100K miles.
Old 04-06-2013, 01:54 AM
Ednica87's Avatar
I tried looking at a g35 diagram, am I just looking for rear dif. Bushing or something different. Thanks!
Old 04-06-2013, 12:11 PM
Tolboothwilley™'s Avatar
If you see oil dripping down the cover of the Diff then it is 99.99% surely going to be the diff subframe bushing. Its very common like mentioned above.
I would recommend getting the whiteline differential bushing set if you are going to replace them
Old 04-23-2013, 04:40 PM
brian8064's Avatar
I too have the same issue on my '04 with only 48k. Took it to the dealership today and they told me that my aftermarket exhaust is routed differently from the stock which is causing it to heat up the subframe bushing resulting in a leak. The told me that bushing cannot be purchased alone and that the whole part would need to be replaced. $1700 some for the repair. They did say that it only leaks when my exhaust gets hot enough to heat up the bushing. They suggested some sort of a heat shield to protect it from exhaust heat. That should be pretty easy but, if thats not the case, and it is a bad bushing, were they correct in telling me the bushing cannot be purchased separately? Seems a little odd to me. It was an Infiniti dealership. I have an extended warranty but they said since its not stock exhaust, it wouldn't be covered.
Old 04-23-2013, 04:46 PM
GreenGoblin's Avatar
The goblin resurrection
Has nothing to do with exhaust its becuase its a single point to mount the diff and when it flexs it will eventually crack and leak out the fluid.
Get an Spl and never worry about it again.
Old 04-23-2013, 04:56 PM
Ednica87's Avatar
^ spl what? I have found z1 motorsports offers the set or just the single bushing? reviews, or best product out there? Best way to tackle this project? Example: dropping differential?
Old 04-23-2013, 04:58 PM
Ednica87's Avatar
So does the diff. Fluid overflow into the subframe or what cuz I don't know how it carries the fluid or is it a different type of fluid you put in?
Old 04-23-2013, 05:28 PM
brian8064's Avatar
Yea, I'm pretty new to the car. Only had it 2 weeks so excuse my ignorance when I ask what an SPL is. Thanks for your help
Quick Reply: oil leak from rear
