random misfire please help
Old Mar 15, 2015 | 12:42 AM
G35-R's Avatar
2003 G35 Coupe 6MT
About the last post, how did you fix your car? I have the same problem.
Old Mar 17, 2015 | 03:34 AM
westsideblu's Avatar
Black smoke means more often then not oil is making it's way in to the combustion chamber through either a gasket valves or piston rings you should do a compression test and a leak down soon and check before it gets worse.
06g35
Feb 14, 2022 05:59 AM
KallDay86
Jan 8, 2016 12:42 AM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
