loud whining noise from engine HELP!
Old Jan 8, 2018 | 10:10 PM
zachdillon's Avatar
Ive had my G35 6mt stored away for about 3 months , i had my plenum off because i was polishing it. i put everything back together , all the bolts are tight, put the battery back in, go to start it , it starts but right away it makes a really loud whining noise from the engine and suddenly dies couple seconds later, i need help
Old Jan 9, 2018 | 11:48 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Is a belt squealing? Do you have a video of the sound?
Was the plenum off for the entire 3 months and was the opening adequately protected? You might have a critter in the engine that is squealing?
Old Jan 9, 2018 | 12:10 PM
zachdillon's Avatar
I do have a video of me inside the car starting it, not sure how i’d post it here though, the plenum was off roughly for 1 month, in an in closed garage. i’m not sure if it’s a belt because i’m unable to go up to the engine bay to hear exactly where it’s coming from because it will not idle, it dies if i don’t give it a little gas. i’m going to have my friend hold rpm so i can hear where it’s coming from. it doesn’t really sound like a belt, it’s very loud, almost need ear plugs.
Old Jan 9, 2018 | 12:36 PM
eazdaskeez's Avatar
Sounds like a belt or a pulley. Funny thing is the exact thing happened to me yesterday. Loud noise while driving and then POP BANG. Idler pulley left me stranded for three hrs on the side of the road. Check your pulleys and belts
Old Jan 9, 2018 | 02:06 PM
cleric670's Avatar
BANNED!!!
If it won't idle at all I'd doublecheck the manifold gasket, you may have pinched the oil fill neck (very common mistake) and have a massive vacuum leak. Since the belts are easy to remove you can just take them off and spin all the accessory pulleys (and tensioners) by hand, if one has a bearing problem it will be unmistakable when turning it by hand.
Post video's to youtube and put the link here it will embed the video automatically.
Old Jan 9, 2018 | 02:35 PM
zachdillon's Avatar
Solved
well, i found my problem, my plenum was pinching my oil fill rubber neck thing, it was causing a vacuum leak! i took off plenum, got the rubber piece out of it, bolted it back, started and ran like a charm!
Old Jan 9, 2018 | 02:43 PM
cleric670's Avatar
BANNED!!!
Yep, SUPER common when putting the plenum back together. Glad everything is working now.
Old Jan 9, 2018 | 09:24 PM
zachdillon's Avatar
thank you !!(:
Old Jan 13, 2018 | 05:18 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
So nice when it is something that easy.
theoneyouwant
Feb 9, 2013 12:17 AM
theoneyouwant
Drivetrain
Sep 4, 2011 11:42 PM
Igor911
26
Feb 16, 2011 12:53 PM
nubi4life
Aug 16, 2010 11:12 PM
mca00176
Mar 22, 2008 06:15 PM
