Changing Clutch Question
Old Nov 19, 2018 | 02:23 PM
nzedwards's Avatar
Has anyone put a automatic motor inside a manual g35? I put a automatic motor inside my manual transmission G. The clutch pilot bushing will not fit into the automatic motor, and someone told that there is a automatic pilot bushing on the automatic motors.
Is there actually a automatic pilot bushing because that thing looks apart of the motor? If yes, how do i get the automatic pilot bushing off? I tried using the bearing puller from auto parts store but nothing happened.
If that thing does not come off, how can i fit the clutch pilot bushing into there? Thanks
Old Nov 19, 2018 | 07:38 PM
RustyNCA's Avatar
I'm in the middle of doing the same thing.
Looking at the back of the motor we just pulled and looking at the shop manual, page EM-137 and EM-138 show a "Pilot Converter AT Model" vs a "Pilot bushing MT Model". My plan was to use a slide-hammer I have to try to pull the converter out. I might also hit the crank around it with some heat and try not to hit the "Converter" so it might be easier to pull.
I don't think you can run the MT until you get the "Pilot Converter" removed.
I attached the two pages from the manual for you. Look for #10 on the pages.
Cheers
RustyNCA
File Type: pdf
Old Nov 19, 2018 | 07:59 PM
nzedwards's Avatar
Cheers
RustyNCA
Thanks, and I have been driving without the MT pilot bushing and the AT pilot converter still attached to my motor since August 2018; however, I have no idea if it is damaging anything such as my transmission. May you post the exact method you performed whenever you get the AT pilot converter off?
Old Nov 19, 2018 | 08:10 PM
RustyNCA's Avatar
Yes, I'll circle back on it, when I figure it out. Interesting you were able to run it with that part still in there, no vibrations or anything? Seems like the front of the input shaft would move around without the support bushing installed?
Managed to get the motor pulled yesterday, now have a car or parts of a car to deal with. Was a nice low miles car before it got clipped on the drivers side.
Old Nov 19, 2018 | 09:25 PM
BradMD_96's Avatar
The engines that have had an AT fitted to them will have an Automatic transmission pilot bushing (this centers the torque converter).
You need to remove this - normally by filling the crankshaft with heavy grease and using a half inch extension or socket (as close to the inner diameter hole size). Hammer this in and the hydraulic pressure should pop out the auto pilot bushing. Google it for more details on this method - I have used this before and it worked.
Old Nov 20, 2018 | 10:50 AM
RustyNCA's Avatar
Yeah, I tried the heavy grease trick when I replaced the clutch in our CTS-V, it didn't work at all for me. Went and bought a slide hammer and popped the bearing right out, so once I find where I "safely" put the slide away, I'll give it a try.
I've also seen people say they use bread in the same manner as the grease?
Old Nov 20, 2018 | 08:06 PM
Blue Dream's Avatar
I drove ttrank's car solo
There are at least 2 videos on YouTube that the guys used the bread trick and yes, it worked.
Old Nov 21, 2018 | 09:56 AM
nzedwards's Avatar
Yeah, but I am pretty sure those videos deal with the MT pilot bushing inside the motor. The bushing on AT are attached on like the edge of the motor, so idk how the bread trick would work in this situation.
Old Nov 21, 2018 | 10:03 AM
nzedwards's Avatar
Nope, no problems except for alot of chatter w/ a stock clutch and flywheel. I assumed it was my throw out bearing going out, but it could’ve been chattering alot due to not having that bushing inside also
alexbass311
May 14, 2010 12:41 AM
skyline03
Drivetrain
11
Mar 23, 2009 07:27 PM
Demonteverde
Drivetrain
Dec 29, 2006 07:01 AM
JZ39
Mar 2, 2005 11:24 AM
