No start after timing chain install
Old Oct 8, 2020 | 09:05 PM
  #31
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You triggered the NATS/IVIS security interlock / vehicle immobilizer, by too many failed attempts, that is VERY indicative that the car didn't recognize your key. I'm guessing that while you were cranking the engine the red LED security indicator on the dash was SOLID RED.
There's steps in the FSM to unlock it from the security lockdown in BL - Body Locks Security, you're probably also throwing code P1610 right now for the immobilizer being engaged.
Try your spare key, check the status of the NATS/IVIS indicator LED on the left side of the dash while cranking.
I think to get out of lock mode it's ignition ON for 5 seconds, turn ignition off, ignition ON for 5 seconds, turn ignition off, ignition ON for 5 seconds then start the engine. So three cycles of ON (5seconds), off, then on the final one you start the engine.
You must use a registered key to get out of lock mode, or use Consult-II/III dealership tool to bypass and give it new keys registries, OR use Uprev tuning software to turn off NATS/IVIS.
Old Oct 9, 2020 | 04:59 PM
  #32
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Datascan2 can also program keys FWIW
Old Oct 11, 2020 | 04:49 PM
  #33
TheEverydayLife's Avatar
G35 premium
So if I replace the ecu does the ENTIRE part number need to match exactly with a new one? Or just a portion of it?
im not finding anything close, I can’t even find evidence of this exact part number anywhere. I guess I’m calling the dealership in the morning.
ashleytea666
Aug 29, 2019 06:09 PM
Meck's G
Jul 24, 2019 08:31 PM
JRandallC
Jan 13, 2017 04:11 PM
Nylax16
Mar 24, 2014 12:58 PM
warzywko
Mar 13, 2011 10:29 PM
