Oil-Change How-To
Old Jul 19, 2003 | 02:24 PM
slinkyboi5's Avatar
Oil-Change How-To
I put together an oil-change how-to for anyone's reference that may want to start changing their own oil and not be sure how to go about it. Enjoy.
http://www.columbusinteractive.com/G35/OilChange
It will soon be hosted at www.g-owners.com
<P ID="edit"><FONT class="small"><EM>Edited by gsedanman on 07/19/03 12:21 PM.</EM></FONT></P>
Old Jul 19, 2003 | 03:49 PM
Msedanman's Avatar
O.F. Administrator
Re: Oil-Change How-To
Excellent work bro. I've copied and pasted the whole article to our FAQ/DIY forum. (credited to you) Thanks from all.
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Jul 19, 2003 | 08:01 PM
Tabz's Avatar
great post slinky! thanks
i noticed the blue engine cover, did u do that urself?
03 G35 coupe SS (GD) 6spd everything but navi
02 QX4 pearl white
00 528 Silver on black
Old Jul 20, 2003 | 12:55 AM
slinkyboi5's Avatar
Yeah, I painted the cover and the battery cover with spray paint. Here's more pics of that: http://www.columbusinteractive.com/G35/ecover
Old Jul 21, 2003 | 06:16 PM
doseas's Avatar
Great write-up. I'd add just one thing to step #7: make sure the O-ring is still attached to the old oil filter (I once had a dealer miss the old O-ring on one rare occasion where I didn't change the oil myself -- needless to say, I didn't make it very far out of the service dept driveway before losing all the oil in the car & I've been religious about checking them since).
Old Jul 21, 2003 | 06:56 PM
Bolocop's Avatar
Why do you need to remove the plastic dust cover on the bottom? Doesn't the rectangular hole cut out allow you to drain the oil and remove the filter?
Bolocop
2003.5 G35 DP/Prem/Navi/Sport
Old Jul 21, 2003 | 09:47 PM
slinkyboi5's Avatar
You can theoretically change the oil through the rectangle...but, I have found that the oil gets on the cover and it's a very tight squeeze.
Old Jul 22, 2003 | 10:11 AM
brooch's Avatar
I don't know if your plastic cover had it, but there is a plastic bolt that holds the cover even after all the bolts have been removed.. This is the last thing u need to remove before the cover can be totally released.
As quoted by gsedanman when I asked about this:
Changing the oil is fun, once you get past that pan. BTW the plastic clasp you're asking about: you have to pry the centre locking pin out a little first then you can remove the whole assembly.
My G is absolutely "Mavelus"!
Old Jul 22, 2003 | 10:15 AM
slinkyboi5's Avatar
Mine did not have a plastic clip or bolt. I only had to remove the metal bolts.
Old Jul 22, 2003 | 06:12 PM
junglist19's Avatar
Slinky,
Thanks for taking the time out for this write-up and pics. I've already decided from another post on this forum that I would change my own oil but this helps tremendously. I go through all kinds of anxiety when I bring my coupe to Infiniti for an oil change.
Detailed Image
Jun 30, 2009 08:54 PM
Detailed Image
May 25, 2009 11:54 AM
supergoldenbat
Jun 28, 2007 09:10 AM
god_of_cpu
Jun 5, 2004 10:26 AM
