advancing timing 2 degrees with NA stock cars
Old Feb 17, 2006 | 01:09 PM
rcdash's Avatar
Hello folks,
I've got CIPHER which allows me to advance timing 2 degrees I believe.
Any safety issues I need to look out for? (my only perf mods so far are MD Iso thermal spacer + K&N)
Should I keep an eye on the AFR? And make sure it doesn't go over X?
(X = what number?)
The dyno on UPRev's site shows about a 8 hp/torque gain from doing this (on a Titan)...
Old Feb 17, 2006 | 03:36 PM
Nodnarb901's Avatar
Subsribes to thread
Old Feb 17, 2006 | 04:26 PM
badtziscool's Avatar
For a second, I was thinking that was your dyno graph. It was my understanding that the VQ motor has a knock sensor that will optimally set the timing to produce the most power without pinging. However, I'm guessing that Nissan has it set so that there's some margin of safety, so you could technically get some more hp by advancing the timing. 8hp? Maybe not.
Old Feb 17, 2006 | 05:29 PM
MechEE's Avatar
I heard from a tuner that the stock timing maps are so aggressive that if you advance it 2 degrees, the learning algorithms will just tune it right back out over time. He said they basically just use it to move the timing back 2 degrees for some added safety witih FI. I haven't verified this myself with the Cipher yet.
Regarding safety issues, I wouldn't worry about it. The knock sensors will save you. And your injected AFRs shouldn't change, just the point where the burn starts in the stroke.
Old Feb 17, 2006 | 09:26 PM
DaveB's Avatar
I've read that advancing the timing via the Consult tool on the VQ35s does absolutely nothing because all it adjusts is the base timing. Once you go WOT, the additional 2 degree advance plays no part in the equation because the ECU pays no attention to base timing at that point.
Old Feb 17, 2006 | 10:31 PM
MechEE's Avatar
Define "base timing". I would assume that the base timing is something relative to which the maps are defined, so I would expect it to offset the entire shizbang. If you know otherwise please do tell.
Old Feb 18, 2006 | 03:28 AM
Originally Posted by HomieG35
Ontop of that I thought it always went advance = torque / retard = horsepower. Atleast thats what school taught me?
I don't think that's quite true. More torque IS more horsepower. Torque is a force. Horsepower is power which is force/time. More force over an equal time equals more power.
With regards to what was said earlier, I think base timing is the timing of the spark at idle. The term came from earlier engines where the timing was physically advanced by the amount of vacuum produced by the engine. So the base timing referred to the point where vacuum was the least. As engine rpm increases, the timing of the spark has to advance in order to keep the burn efficiency high. Prior to knock sensors, the advance of the timing was just an estimate. That's why advancing the timing on a 5.0 Mustang was worth 10hp. The factory setting was too conservative. Now a days with knock sensors, an engine can run closer to that optimum timing without much danger.
Old Feb 18, 2006 | 09:54 PM
MechEE's Avatar
I think what is normally meant by "more torque" or "more horsepower" is "more low-end torque" or "more high-end torque", the latter translating to more peak horsepower.
And torque is a moment, not a force. And power is work over time, not force over time. More force over the same distance over an equal time equals more power. Not that this is really relevant to the discussion, but I wanted to clear that up.
Old Feb 19, 2006 | 01:50 AM
dovla's Avatar
On Boxing Day I had Cipher advance timing to 17 degrees. I thought I felt difference. Any gain was not as when ½” MD spacer was installed. But it could also have been placebo effect. Month latter, I had half a tank of 91 octane gasoline put by mistake and then filled up with 93 octane. Few days after I had P0303 DTC. It might be related or not, regardless, I changed it back to 15.
Old Feb 19, 2006 | 02:45 PM
rcdash's Avatar
I have a GTech so I could test it. I didn't expect much - just wanted to be sure it wasn't going to harm anything.
dovla, not sure what that code is -> I don't think 91 octane should have caused it, that's still "premium" fuel.
Hmmm.... thinking no point pursuing this.
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
DRG35R
Jul 31, 2015 10:23 AM
Nog89
Jul 21, 2015 03:02 AM
quickspeed6
24
Jul 15, 2015 11:06 AM
