Catchin' Oil
Old Jun 18, 2006 | 09:53 PM
  #136
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by bikesbikes
Hey guys. ARC makes a catch can for our cars. They list it for a 350z but it fits.
& how much is it??
ARC is usually on the expensive side
:edit:
LOL... like I thought $250 .....gimmie a friggin break!
Old Jun 18, 2006 | 10:42 PM
  #137
bikesbikes's Avatar
Originally Posted by inTgr8r
& how much is it??
:edit:
Yeah ARC is pretty expensive. I got mine off a guy who sold his 350 and never got to install it so it only set me back about $100 CDN.
You gotta admit they look good.
Old Jun 19, 2006 | 01:23 AM
  #138
godmans's Avatar
does anyone have a website or local (canada..) place that I can buy some rigid vaccum grade hoses?
All that I can find don't really seem to withstand the heat + vaccum force that the hose is going to go thru..
I can't even find fuel injector hose locally :<
Old Jun 19, 2006 | 01:27 AM
  #139
Andy2434's Avatar
Fuel Injection Hose is what I finally settled on and it works great. I had to go to quite a few shops to track it down. Good luck!
Old Jun 19, 2006 | 04:08 AM
  #140
Bobalude's Avatar
about the hose, is it possible to goto a dealership and buy the OEM hose?
In reference, trey.hutcheson's pictures a few posts up, the rightmost picture shows the catchcan with two different types of hoses. One I assume is OEM and the other is picked up elsewhere.
Old Jun 19, 2006 | 12:04 PM
  #141
godmans's Avatar
Please let us with regards to buying the hose from the stealership, cause I am trying hard to get a hose that can withstand extreme heat + vacuum
Old Jun 19, 2006 | 12:12 PM
  #142
bosssho's Avatar
How long was the Fuel Injection Hose and how much and where did you end up tracking it down? Thanks.
Old Jun 19, 2006 | 01:03 PM
  #143
g35rcr's Avatar
i would get 2 feet just to have some extra while you make your setup...you can get it at autorace shops that build engines
Old Jun 19, 2006 | 04:25 PM
  #144
G352NV's Avatar
Never enough
Wow I missed this one. Great mod!
Old Jun 19, 2006 | 04:28 PM
  #145
binar's Avatar
I picked up 2' at PepBoys for about $5.
I believe most auto parts stores will have the hose. Give'm a call!
Old Jun 19, 2006 | 04:55 PM
  #146
InTgr8r's Avatar
Donavan has some silicone reinforced vac line..... LINK
I talked to him already & am just waiting to hear back; I'll let you know
Old Jun 19, 2006 | 05:43 PM
  #147
bikesbikes's Avatar
That stuff should do the trick.
Wow I didn't realize it came in so many colors.
Old Jun 19, 2006 | 07:06 PM
  #148
Andy2434's Avatar
I found the fuel injection hose after going to 4 Kragen auto parts stores. With the regular fuel/emissions hose, I didn't like the fact that the line would collapse at idle and expand back under light throttle. The fuel injection hose quickly remedied that issue.
Old Jun 20, 2006 | 12:23 AM
  #149
godmans's Avatar
Well..I gathered all the parts (including the damn fuel injector hose) in around 2 hours.. and got the whole thing installed
However, I do notice that there is quite a bit of buzzing sound coming from the Oil Catch Can.. I wonder is it because of the fiter in place? or does anyone else experience this? (I know you guys think that the "air sucking" noise is from the filter, but I have already drilled a 1/4" hole at the buttom of the white filter..so I am not sure wherere is the buzzing sound come from... Engine ? or if there is a leakage in my fittings)
Anyways, I have taken a short 15 mins drive and have noticed nothing but those buzzing sound. It seems like the fuel injector hose is able to hold up against the vacuum
Thanks
Old Jun 20, 2006 | 06:51 PM
  #150
Andy2434's Avatar
Try removing the white filtering element. As DaveO had mentioned earky on, it may be too constrictive. I have made a few of these without the white filtering element and there are no issues, at this time.
