Makeshift Oil Catch Can
Rating: Thread Rating: 7 votes, 5.00 average.
Old Nov 15, 2010 | 05:21 PM
  #241
jon121587@yahoo's Avatar
Let us kno if u have residue in the hoses after the catch can setup. ( the hose going into manifold) thanks
Old Nov 15, 2010 | 06:05 PM
  #242
ShaneH85's Avatar
I stuck a q tip in my hose and there was oil, not enough to soak the q tip but some was there. But for the money we have in this system I can't really complain. But the amount of oil these things catch is amazing.
Old Nov 17, 2010 | 06:10 PM
  #243
Nice Nice are u going to keep the double catch can setup . So with the setup u just tryed U noticed a diff though right. I mean it sounds like its better now if u used a q tip and it didnt soak.
Old Nov 18, 2010 | 07:51 AM
  #244
ShaneH85's Avatar
Im going to try and find a way to hide the 2 catch cans better, or im just going to buy a real one now that i know it works. I mean to fully get it right, we need a filter that catches the oil in one end and DOES NOT release oil back out the other side. But thats just for the looks, because the 2 are working great i will just check them once a week and know thats a little less oil going into places it shouldnt.
Old Nov 18, 2010 | 06:24 PM
  #245
Today im going to buy another home depot catch can to setup also because the fact that oil gets past the first one gets me paranoid LOL. Id rather have two points where the oil liqufies rather than one catch can. Thanks for the info bro.
Old Nov 18, 2010 | 06:37 PM
  #246
msommers's Avatar
The corvette catch can's design is fantastic and would really recommend it.
Old Nov 18, 2010 | 09:49 PM
  #247
ShaneH85's Avatar
Where did you get it from? Is there a link you can post? Thanks man
Old Nov 19, 2010 | 02:44 AM
  #248
Okay jus bought another Catch can from home depot and figured some thing out. the filter that comes with the Catch can is actually Effective because it filters out Liquid into AIR. So on my setup up i will have the first HD catch can with out a filter and on the same hose have the second HD catch can with the filter. The reason why i have it setup like this is because on the first HD catch can (Without filter) the Oil will have the first point of liquifying and by the time it gets to the second HD catch can it will be filtered to AIR. Thats if it makes it to the second HD catch can. Dont want to confuse everybody LOL but it really makes sense.
Old Nov 19, 2010 | 08:51 AM
  #249
ShaneH85's Avatar
hey jon that makes perfect sense I'm putting my filter back on my 2nd catch can when i get home. As of right now i could care less how my engine bay looks until i get the outside like i want it. So when i go turbo ill buy a real catch can and mount it where it looks good. But for now this is the best diy on g35driver.com imo.
Old Nov 19, 2010 | 08:57 AM
  #250
V35 Skyline GT's Avatar
6MT Coupe
Start at post 218.
Old Nov 19, 2010 | 04:40 PM
  #251
OCG35's Avatar
I know the HD (Husky) filter design now is a bit different than the original (I used to have the old one)... but if the filter media is the same I would not use it. It will impede airflow (especial once it gets saturated with oil residue - and if there isnt enough oil vapor to do that, then you dont need the second can anyway).
Old Nov 19, 2010 | 04:46 PM
  #252
rcdash's Avatar
I doubt it will impede airflow since it's designed as an air filter. I would use it. If you can keep a cheap vacuum gauge on the line, you'll know for sure it's flowing fine.
Old Nov 19, 2010 | 04:51 PM
  #253
OCG35's Avatar
it's designed for condensation from air compressor... not oil.
It wasn't theory I stated - I tried various configurations with the filter and even the helical piece that typically goes on the inside cover... doesnt work as well as open chamber.
Or they can try it and come to their own conclusion.
Old Nov 20, 2010 | 01:37 AM
  #254
Could u maybe post a pic of the old HD catch can ur taking about because it may be diff than ours . Thanks
Old Nov 20, 2010 | 02:13 PM
  #255
OCG35's Avatar
the very first post of this thread.
TMK the only difference is the valve at the bottom... but maybe the filter element is different too?... even if it is different, its not designed for oil - you will still probably have the same problem I ran into (if you read really old posts about this mod, lots of discussion about that filter = no one uses it, and for good reason).
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
