Exterior-Vendor Includes spoilers, body kits, tail lights, gauges, shift knobs, and other styling components
Aluminum Under Tray (Splash Shield) for G35/350Z/G35X/G37/G37X
Old Aug 25, 2012 | 02:55 PM
  #136
Gdoser's Avatar
Originally Posted by Tolboothwilley™
pms replied, shrouds shipped
Pmed u
Old Aug 26, 2012 | 12:05 PM
  #137
slick_daddy's Avatar
i sent a pm hoping these fit the 07
Old Aug 26, 2012 | 12:32 PM
  #138
MPG35fiend's Avatar
LOVELY! looks way better then the ZSPEED one Fsho'.
would love one but i think I'm too low to get another one. is clearance on this better than ZSPEED?
Old Aug 27, 2012 | 05:22 PM
  #139
Tolboothwilley™'s Avatar
Originally Posted by Gdoser
Pmed u
replied
different version for the HR motor equipped G35 (2007-2008 Sedan) and G37s - sent you a pm
Its tough to say about clearance being better - i kept clearance as good as possible but its tough to say because everyone has diff roads/speed bumps. I don't scrape on my shroud i just scrap my motordyne exhaust everywhere i go!!
How low are you?
Old Aug 27, 2012 | 05:35 PM
  #140
MPG35fiend's Avatar
replied
How low are you?
I'm pretty damn low for an "X". Already replaced my smaller undertray 3 times and the engine cover twice..
Old Aug 27, 2012 | 06:05 PM
  #141
stock undertray?
Old Aug 27, 2012 | 07:52 PM
  #142
MPG35fiend's Avatar
Yea. One of them was and the last one was the zspeed one which was worst then oem bc it rattled like crazy bc bolts was stripped from the oil filter door and a few near my cross member bar and it sucked! Made my g sound cheap from all of the rattle..
Old Aug 27, 2012 | 08:10 PM
  #143
EEk, thats too bad. Never had any issues with that.
Did you scrape w/ that one a lot?
Old Aug 27, 2012 | 08:23 PM
  #144
MPG35fiend's Avatar
Yea man! I'd love to buy one of yours but I'm afraid same thing will happen to me again. From what I researched the Xs bottom end sits lowest from all the other models due to the cross member bar. That's why I can't be totally slammed which totally sucks!
Old Aug 27, 2012 | 08:31 PM
  #145
what happened with the metal one?
Old Aug 27, 2012 | 08:37 PM
  #146
MPG35fiend's Avatar
after the oil door came off the whole thing just fell apart.... hit a bump and the bar where the oil door went snagged off. it just worst after bolts kept getting stripped off.. then finally took it off. it was embarrassing riding around with that rattle...
Old Aug 27, 2012 | 11:48 PM
  #147
interesting - thats curious that you lost the oil door too? I could make one without an oil door for you, if you just wanted the protection. Just a thought.
Old Aug 28, 2012 | 12:03 AM
  #148
MPG35fiend's Avatar
the door wasn't the problem... well not at first.. i hit a bump and it stripped the bolt heads off and it hung for a longtime before i pulled it off.... could you make one that inverted up instead of down?? I've seen one that is inverted up instead of down.... it looked a bit funny but I'm sure it would be a lot more clearance!
Old Aug 28, 2012 | 12:09 AM
  #149
it would be impossible to remove the door to change the oil...you're better off just having one with no door.
I remove my rear piece every time i change my oil anyways - since i have a lower tie brace right under the drain plug. It is still quick to remove since you don't have to do the bumper section, but then easy to work on anything.
Old Aug 28, 2012 | 12:23 AM
  #150
MPG35fiend's Avatar
bumper section?
