question about a problem i have !!
Old Nov 2, 2007 | 10:18 AM
iamericgee's Avatar
Question question about a problem i have !!
as you guys know i got the kinetix v yesterday and i trie to install it last nite
so i get all the hardware off the stock plenum and start getting ready to put on the new one everything was going great i start hooking up the hoses but there seemed to be to hoses that i didnt know where they went ! so i connect them together to see if that would do it so i finish bolting everything on intake etc... so i turn my car on and next thing u know the car starts to sputter and then shuts off like if there is a vacum leak or something !! the hoses that i am refering to are right behind the plenum near the intake i believe it had some kind of fluid coming out of it maybee coolent i really dont know but anywho there isnt a spot on the kinetix to hook these hoses up to ... can somebody help me figure this out please !!!!!?!??!?!/i would like to get this installed tonite if possible !! thanks for any help
Old Nov 2, 2007 | 11:23 AM
_jb's Avatar
_jb
Photographer
I believe the connectors you are talking about route water through the plenum near the throttle body. They help to keep the throttle body warm during cold winters. If the Kinetix is plugged, it shouldn't cause a problem... lots of people plug them.
Make sure the rubber gasket around the oil filler cap didn't get stuck under the plenum... also make sure the plenum isn't sitting on top of one of the thin metal brackets for the wire looms.
Post back if that doesn't help... Maybe somebody with a Kinetix will have some other ideas...
Old Nov 2, 2007 | 12:21 PM
WILD121's Avatar
You will know if you have a vacum leak you will be able to hear it. As soon as you put on a new plenum some cars sputter a little because the computer has to adjust to the new mod. I had a problem with starting the car and the idle was very low. Give it about a week and the computer will adjust.
Old Nov 2, 2007 | 12:39 PM
black_sedan's Avatar
if it has the coolant coming out of it, its the 2 hoses that connect to the throttle body. either you can put them back into the TB or bypass them with a tee fitting.
Old Nov 2, 2007 | 01:18 PM
Gilley's Avatar
Those hoses connect to the TB.
Old Nov 2, 2007 | 03:54 PM
iamericgee's Avatar
thanks guys for the advice i went to the kenetix web site and downloaded
the how to manuel and isee where i messed up i didnt do a couple of thing that i should of done !!! ugh !! well at least i learn from my mistakes !!! peace out !!!!!!!!!!!!!!!!!!
Old Nov 2, 2007 | 04:26 PM
Gilley's Avatar
It's good to follow instructions.
Old Nov 2, 2007 | 06:49 PM
SFLG35's Avatar
FGC President
only sometimes.
i rarely follow them and never follow them when they arent provided.
Old Mar 1, 2008 | 05:56 PM
hipvspec's Avatar
um...
Old Mar 1, 2008 | 07:18 PM
w0ady's Avatar
fgc moderator
Originally Posted by hipvspec
um...
4 months later...thanks for the help!
Srinidhi
Aug 7, 2015 03:38 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
EasySausage
Jul 14, 2015 11:17 PM
