MREV2 and Stillen SC?
Old Aug 18, 2006 | 12:36 AM
ChiefyMan's Avatar
I'm curious as to if you can have both of these, MREV2 AND Stillen SC, or do you only go with one or the other?
Thanks!
Old Aug 18, 2006 | 01:41 AM
hai109's Avatar
I don't think you can because you will use the new stillen manifold...
Old Aug 18, 2006 | 01:46 AM
ChiefyMan's Avatar
That's what I was thinking, just needed clarification so I could decide where to go with modifications.
Old Aug 18, 2006 | 07:40 AM
superchargedg's Avatar
you cant cause the stillen replaces the upper plenum.
Old Aug 18, 2006 | 12:38 PM
ChiefyMan's Avatar
But isn't the MREV2 the lower plenum? And it says it can work with an aftermarket plenum if I read correctly.
Old Aug 18, 2006 | 12:42 PM
denverinfiniti's Avatar
The stillen replaces the upper AND lower plenum
Old Aug 18, 2006 | 12:50 PM
ChiefyMan's Avatar
Oooh k, gotchya. Thanks for the clarification. Well, now it's just time to decide rather to go with the S/C or the MREV/spacers.
Hey, if I went turbo instead of S/C, would the plenum still be replaced? If not, would it be noticable, the different between turbo and turbo + MREV2/spacers?
Old Aug 18, 2006 | 02:07 PM
ttrank's Avatar
Grocery getter
Yes the Stillen replaces the entire plenum.
All the other kits (SC/Turbo) keep the plenum. If you go with something else at least get a spacer.
Old Aug 18, 2006 | 02:11 PM
thats what i meant to say,i was just slightly retarded this morning.
Old Aug 18, 2006 | 02:16 PM
Yeah on any other SC or turbo you keep the stock plenum. I installed a 1/2" spacer on a Vortech SC'd coupe and he said he felt a difference in the butt dyno
Old Aug 18, 2006 | 11:49 PM
ChiefyMan's Avatar
Argh, hmm... So MREV2 + 5/16 spacer (iso) + Vortec S/C would work well together? Would I be gettin around or above 300 RWHP? (I got 5AT) How about TQ? And the power band?
Old Aug 18, 2006 | 11:52 PM
ChiefyMan's Avatar
Also: http://infinitipa.zoovy.com/product/4NZ218-030SQ
Good price? And I assume that would work w/ my 5AT sedan (2003) as well as any G35?
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
