vortech and mrev+/mrev2
Old Aug 29, 2006 | 05:32 PM
slimjim's Avatar
Does anyone know how MREV+/MREV2 affects vorteched engines?
Old Aug 29, 2006 | 08:21 PM
Mr_pharmD's Avatar
if u get it tuned it should produce good gains.
Old Sep 1, 2006 | 12:07 PM
Hydrazine's Avatar
It'll give even more gains than when NA.
Old Sep 1, 2006 | 05:00 PM
FI'ed G's Avatar
But isn't that with Mrev+ you loose power on top? so since Vortech's power are all up in the higher RPM then will it just loose some of the power compared to stock plenum?
Old Sep 1, 2006 | 05:06 PM
Mr_pharmD's Avatar
i believe for rev up motors but non rev nope. In any case, they both will increase hp/tq inside the curve where it counts the most.
Old Sep 1, 2006 | 05:12 PM
FI'ed G's Avatar
This is true for NA but Vortech doesn't hit full boost until 4K since Mrev power on Revup die around 6K you're loosing power up top There was tread in MY350 that had to swap back the stock plenum because of the lose power. Anyways either way good thing I still have my stock plenum just in case
Old Sep 1, 2006 | 10:54 PM
QuadCam's Avatar
Vortech doesn't hit full boost until 4K :
actually, the higher you rev a vortech, the more boost it makes. It's impeller speed is directly proportional (internal gear multiplier) to the engine rpm. Until you spin the vortech past its efficiency point, the boost is gonna climb......so in short - NO, the vortech does not make full boost at 4K rpm. It's going to make full boost at redline.
Old Sep 1, 2006 | 11:02 PM
Hydrazine's Avatar
No. That was with the first generation of MREV.
You can see the dyno plots on the Motordyne website to see what it does NA.
There are many people who tested both revup and non revup plenums on their FI system. In all cases, the non revup plenum did MUCH better when FI.
Old Oct 29, 2007 | 11:17 AM
Sportcoupe35's Avatar
Ok, so I have an 06 Coupe 5AT with the Vortech. Will the MREV 2 + 5/16 spacer be a good addition??? I would need a retune correct?
Old Oct 29, 2007 | 11:47 AM
joe603's Avatar
So the MREV2 is "non revup" lower plenum correct?
To be clear, the MREV2+spacer on a revup engine (05+) will have more gains using FI than a revup engine not using MREV2+spacer. Is this a correct statement?
Old Oct 29, 2007 | 03:00 PM
Hydrazine's Avatar
The MREV2 is a modified nonrevup lower plenum.
Yes. I have not tested it FI personally, but there have been several users on MY350Z.com who reported significant gains with it.
It was also used by GTM when they built their 850+ HP TT Z.
Old Oct 29, 2007 | 03:26 PM
joe603's Avatar
sounds good! thanks!
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
n2fooz
Sep 4, 2015 07:46 PM
