STS remote mount turbo
Old Jun 12, 2007 | 04:26 PM
  #46
FI'ed G's Avatar
Originally Posted by digital1986
I love this setup. My buddy with a 350z has it installed and he is over 400 rwhp. Its funny how he can beat TT cars that have spent over 9-10k on their setup!!!
I know one in your area that has the STS but he's boosting 10PSI with 400HP and 420TQ.
Old Jun 12, 2007 | 05:21 PM
  #47
Jeff92se's Avatar
Red Card Crew
Originally Posted by ttrank
Still makes me wonder how bad that driver is.
I found the 4.5 and 8.5 psi dynos and plotted them vs my 4.8 and 8 psi dynos just to see how they perform vs the Greddy. The only ones I could find didn't start until ~2500 rpm so a lot of the lag is already taken into account.
Is that STS dyno from here? http://www.my350z.com/forum/showpost...8&postcount=49
It's interesting that the curves match except for the hp / torque actual numbers.
You have to remember that the STS is pushing though a stock exhaust while you get to run headers and bigger downpipe/cat back pipes.
Old Jun 12, 2007 | 09:06 PM
  #48
ttrank's Avatar
Grocery getter
Yea it is.
These were the only numbers I had to go with so I did it just to see. It doesn't prove much. They are different types of dyno's. I have no idea on that tune either. My tune is super-safe with a lot of timing pulled for extra safety here in the 115 degree summers.
I don't have headers, I have turbo manifolds. They are not any larger than the stock manifolds but made to fit the Greddy Turbos.
I'm not saying this is a bad kit or anything. Just not for me. I'm sure they will sell very well. I got my kit with plans to build the motor for more power and don't think this is the best kit for that kind of use.
Old Jun 12, 2007 | 11:01 PM
  #49
FI'ed G's Avatar
Yea it is.
ttrank first plot is not the same as your link (Jeff92se). The link that you posted is my Dyno and TTrank's plot is from goosegoose. Goosegoose and mine are different setup. My charge pipe is re-routed to go through the exhaust in the middle. Goosegoos setup has the charge pipe running at the side by the jack railing. I forgot Goosegoos high boost map psi but mine is 8psi. both of us are running on stock exhaust and Cat.
Either way TTrank is right, this kit is not for someone who want to go all out or want a monster setup. Just like any ST kit they are all for mild setup and really max out after 450whp.
Old Jun 13, 2007 | 02:11 AM
  #50
Jeff92se's Avatar
Red Card Crew
Athens. Is that your car that they modded their kit for? Wow. But yes, I agree with you guys. This kit isn't the one for big power. Honestly, I'd be more than happy with 350hp at the wheels much less 450WHP! It's nice it comes with a nice ecu like the UTEC vs something like the Stillen SC that comes with the SS box.
I wonder if opening up the stock exhaust would help things?
Old Jun 13, 2007 | 05:30 AM
  #51
FI'ed G's Avatar
Ok, I've been driving all night and let me tell you 360whp is more than enough on the street. I've been driving with the 8psi map and tried the 5psi map and I think it's still more than enough for daily driving. I gave my friend a ride who is very hard to impress and he was amazed how fast it was even at 5psi. Kinda weird coz I know I can spin my wheels even at third when I was NA but with this setup I'm having problem spinning at 2nd I think it's either my stock clutch is slipping or not grabbing hard enough. Julian said opening up the exhaust with test pipes and heat wrapping the pipes will help a lot. Right now my intake pipe is right next to the exhaust and Cat and that is probably robbing me some more HP. Julian measured the intake temp and it's almost the same as the TN.
I think I can still squeeze some more HP down the road by heat wrapping the intake pipe and the exhaust side plus removing the Cat will help the exhaust flow better. Utec really help a lot in term of reliability coz it can pull some timing when it detect some Knock. Utec's boost controller solenoid is also nice since in one flip and you have your boost and Map with it The STS kit is having the feel of Turbo but with the jet whining of a SC (almost ) and it is loud but yet pretty quite under no boost. I'll write a review once i'm done abusing this car so stay tuned.
Old Jun 13, 2007 | 01:22 PM
  #52
ttrank's Avatar
Grocery getter
Very nice!
I agree that ~350-400whp is a lot for street driving and much more becomes useless and more of a smoke show. Soooo much fun and the rush of torque you get from a turbo car is such a rush. My Stillen stage 4 never felt that fast because it was so linear. It was deceivingly fast. Turbos are more of an in-your-face fast.
When you say you are having problems spinning the tires in 2nd, is that chirping or breaking loose totally? If you are talking about chirping the reason is the little bit of lag you get between shifts? When you let off you blow off your compressed air in the charge pipe and have to refill it before you get all that power back. That is a lot of pipe coming all the way from the back of the car and through the IC. It doesn't take long, but long enough to take away that instant surge you had N/A. My car will just barely chirp 3rd but once the boost kicks back in a half second later the tires will come loose.
Old Jun 13, 2007 | 01:26 PM
  #53
Jeff92se's Avatar
Red Card Crew
I wonder if a recirc valve would be better. Athens, is it THAT loud? ie.. louder than a Stillen exhaust na? I'm still thinking a muffler could be untilized in some way?
Old Jun 13, 2007 | 01:51 PM
  #54
FI'ed G's Avatar
Very nice!
I meant both. I'm having a hard time chirping and at the same time my tires doesn't break loose even in 1st The car really feel fast and scary especially on WOT but my tires doesn't break loose on 1st and 2nd even at WOT all the way to redline. temp was about 68 deg.
Old Jun 13, 2007 | 02:07 PM
  #55
FI'ed G's Avatar
hhhmmm, the exhaust sound is not that loud. it's like not having a muffler but with better tone and not that loud. It's hard to explain, I think the sound is a combination of having an aftermarket exhaust and no muffler combined I think I just confused my self there
Now when you're on boost that is a different story. You won't notice the exhaust but you'll here the spooling of the Turbo and when the wastegate open… game over I like the sound coz it tell other cars to leave you alone coz you mean business People are looking at me when I pass by them. The bad thing I guess is that Cops can hear you too If you stay out of boost then you are ok (stay below 3.5krpm) coz the TIAL BOV is quiet on below 3psi. My friends Greddy kit (Civic ) BOV is loud even at low psi.
Old Jun 14, 2007 | 10:38 PM
  #56
digital1986's Avatar
I dont think its quite that high, and also we have bad news
He is selling his Z!!!!! It sucks now our lame a$$ meets just got worse haha I would buy it but I want a 4 door car.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
Claudiu
Sep 26, 2015 01:04 PM
