Stock motor with forced induction . . . how badly did you push it?
Old May 13, 2014 | 01:42 AM
  #331
TheJuice401's Avatar
yay another thread with 100+ pages for me to read. fun
also say i have my stock intake, and an injen sp intake
does the vortect SC replace my intake system, or can i use the injen sp intake? because i see alot of pictures and they all seem the same. thanks.
Old May 13, 2014 | 02:22 PM
  #332
herrschaft's Avatar
Originally Posted by TheJuice401
does the vortect SC replace my intake system...
yes
Old May 13, 2014 | 02:55 PM
  #333
BeerViper's Avatar
Originally Posted by herrschaft
yes
This is not entirely true ... the "intake system" is comprised of several components, one of which is the intake tube from the air filter box which will be replaced by the Vortech intake tube and allows the new filter to sit in front of the pulley system. You will not be able to use your Injen intake unless it was custom designed for use with the Vortech setup (like mine). The stock intake manifold is another component and can remain stock.
Old May 13, 2014 | 03:04 PM
  #334
That G Gray's Avatar
^k show me your pic with your CAI thats bolted to your blower.
Old May 13, 2014 | 03:19 PM
  #335
ok so what you guys are saying is, i should return my injen cai since i can not use it with a vortech SC correct??
  #336
we can only lead the horse to the water...
Old May 13, 2014 | 03:29 PM
  #337
herrschaft's Avatar
He was referring to a CAI, not the manifolds.
Old May 13, 2014 | 03:46 PM
  #338
BeerViper's Avatar
Here's my setup with custom built Injen intake, I've added a strut bar since this pic:
Old May 13, 2014 | 03:48 PM
  #339
BeerViper's Avatar
Correct, look at my picture above as it is custom built for Vortech...
Your Injen CAI will not work with a Vortech setup
Old May 13, 2014 | 04:04 PM
  #340
awesome thank you!
Old May 14, 2014 | 10:58 AM
  #341
Eno's Avatar
Eno
If you can't even do that, then you are going to hate your life when the work actually begins.
Old May 14, 2014 | 11:03 AM
  #342
WhosUrBuddiee's Avatar
100 pages? You must be on noob settings.
Old Nov 24, 2014 | 10:17 PM
  #343
Conway_160's Avatar
04 G Coupe. Procharger with 12 psi pulleys. First dyno trip put down 360whp at 5300rpms but maxed out my RC440's and my stock Maf. Went back 2'ish weeks later with my RC700's and my modded MAF and car lasted roughly 2.5 hours on dyno and finally died on the 3rd full throttle pull. Washed out the bearings and seized the motor.
Old Nov 24, 2014 | 10:41 PM
  #344
ScraggleRock's Avatar
My condolences
Old Nov 24, 2014 | 11:27 PM
  #345
Conway_160's Avatar
Originally Posted by ScraggleRock
My condolences
Yep, very sad day hopefully car will be running again around tax time.
