Vortech SC owners:What HFC's are you running??
Old Jul 7, 2007 | 03:27 PM
Mr_pharmD's Avatar
Originally Posted by booger
Running no cats .... you will lose very little trq down low . You will run less boost up top , but make better whp on less boost compared to running cats .
all cats are not the same....like I said , RT's out flow any other cat . When you lose the rasp an open exhaust makes , the cats are starting to get restrictive . More boost with restrictive cats does not mean more power
I dont even consister RT as cats bc they llook more like test pipes. U have to remember hes running stock headers which are only 2.00 outlet so if he gets cats that are inlet 2.00 and expands toward 2.5 to connect to the exhaust (which I'm assuming is 2.5) then that will be the best combo of air flow. I really dont see any restrictions with this setup. So I still recommand the kinetix due to the 2.3 inlet and 2.5 outlet.
Old Jul 7, 2007 | 04:43 PM
Barzten1's Avatar
Fast Intentions HFC's!
Old Jul 7, 2007 | 11:07 PM
trey.hutcheson's Avatar
Hexxum, but I've run both crawfords and kinetix, but I'm NA, so my information may not apply directly to you. The kinetix sounded better IMO, but they had fitment issues. After weeks of bending and hammering the underside of the car, I was finally able to get them to fit well enough, but I still had an occasional cat/frame contact flutter.
The crawfords had zero fitment issues. The sound was also deeper, whereas the kinetix offered a more euro flavor to the exhaust note. I didn't notice any major differences in top-end power, but the crawfords definitely helped out down low versus the kinetix. Also I picked up almost 1mph in the 1/4 with the crawfords versus the kinetix. Again, this was all NA, so YMMV.
Old Jul 7, 2007 | 11:10 PM
G Thizzle's Avatar
Fast Intentions Test pipes... flow is good but you lose tourqe....
Old Jul 8, 2007 | 03:29 AM
Hexxum001's Avatar
Well, test pipes are not a choice for me. I know it's illegal to change your cats period but at least having cats will lessen my chance of getting busted. I'm sure most cops wouldn't be able to tell the difference between stock cats and aftermarket cats. And if need be, I could just switch back to the stock cats. I really like the FI HFC's but don't want CEL's so I will be watching what happens with extreme's car.
Old Jul 8, 2007 | 04:25 AM
Skaterbasist's Avatar
Retired SuperMod
Extreme bought some FI 400 HFC, which mean they are ceramic... which means they can break down much more easily.
FI 300 Cell are Metallic, and they are recommended for Forced Induction applications because they are very durable.
You can check out Hero's (Calvin's) review about these cats if you haven't already; IMO, im completely sold on them. If not for Fast Intentions, I would go for Crawford.
These guys (FI & Crawford) are have proven products that work well
Old Jul 8, 2007 | 12:54 PM
Sundeviljay's Avatar
i've had the FI 300 cats for almost a year and have had no CELS
Old Jul 8, 2007 | 12:57 PM
booger's Avatar
WHAT EXHAUST DO YOU RUN and is there any rasp ?
Old Jul 8, 2007 | 01:05 PM
I have the APS 2.5...when down shifting to first in manumatic i get a tiny bit of rasp. It's very mild. It's only when I am going very slow...if i give it some gas and then let go...The cats made my exhaust almost twice as loud!! The APS was very quiet before the cats
Old Jul 8, 2007 | 03:00 PM
Hexxum001's Avatar
Good to know. Thanks Jay! I am really leaning towards these.
Old Jul 8, 2007 | 03:26 PM
SIN3's Avatar
was thinking about going randoms... but still running stocks... have fun with your kit.. i am runing the same set up on my 04 minus the stand alone. 4 tickets later and just got off from going 145mph on 55 south (car not impounded or ticket given due to technicality). with this set up it will take about 95% of the cars on the road...
Old Jul 8, 2007 | 08:18 PM
rcdash's Avatar
The FI cats do not have a heat shield on them so they look very different than OEM (they look better, but that is a bad thing come inspection time). I tried asking Tony about a solution to this, but he didn't really have a good lead on where to get OEM-looking heat shields to wrap around the cats.
Thebaws11
Jul 2, 2021 11:36 AM
DRG35R
Sep 16, 2015 05:33 AM
Cbohannan101
Sep 12, 2015 10:32 PM
n2fooz
Sep 4, 2015 07:46 PM
G35CO
Sep 4, 2015 09:27 AM
