Any doubters of IC sprayers LOOKS ;)
Old Aug 23, 2007 | 01:31 AM
Meatshackle's Avatar
Deep Sea Moderator
If it is true, good luck with 460hp on a stock block.
Old Aug 23, 2007 | 08:04 AM
Audible Mayhem's Avatar
NO WAY is this possible, i have cars on my dyno EVERY day. we have sprayed nitrous on and in every thing possible.
this is total BS, some is either A: really messing with you or B: trying to push a product here.
the MOST that we have ever seen, and this is coming from me personally, is a 15 whp gain when we emptied a 5lb bottle on the IC, engine, piping, turbos, EVERY part.
this is total BS and i will give you $1000 dollars if you can do the same thing on my dyno...
EDIT, it would take a 80 shot to give you those numbers sprayed directly into the intake. nitrous would cause and instant jump in tq and hp that you dont have. i think the guys were messing with you at the shop and gave you someone elses graph...
PLUS 460 hp on an AUTO on the stock block isnt happening either
Old Aug 23, 2007 | 10:45 AM
rcdash's Avatar
You mean car parts, right?
Old Aug 23, 2007 | 12:19 PM
we have chased each other around with it as well...
Old Aug 23, 2007 | 01:30 PM
Triple8Sol's Avatar
remember, correlation does not imply causation...to come to that conclusion is very illogical
You tell 'em, Spock!
Old Aug 23, 2007 | 03:32 PM
ttrank's Avatar
Grocery getter
One spray for you, one spray for me, one spray for the car. Now everyone is happy.
Old Aug 23, 2007 | 04:05 PM
denverinfiniti's Avatar
Well like I said on the Z forum. I'm not sure what happened to make those numbers just posting what happened. But want to say thanks for not turning this post into a bitch fest like on the Z forum
Old Aug 23, 2007 | 06:57 PM
minus500's Avatar
I think most people here are a little more docile. The Z forum can be harsh but, in all honesty there is no way those numbers are correct. I also think your a little low for a 2.87 and the mods you listed. Talk to your tuner and see where the issue is. Good luck and let us know what happens.
Old Aug 23, 2007 | 07:21 PM
djniknala's Avatar
Sherlock Holmes would be proud
After a little investigative work I found out that the lower run was actually the more recent run. So the higher number is your baseline and imo not your car either. Look at the graph I posted from the Dynomite(im my best JJ from Good Time's voice) website and you will see that it puts more recent pull's power output in the lower right hand corner and also annotates the old run automatically with a (1) next to it. Your car is making 350whp and 310tq which is on par with your mods and altitude. Sorry to burst your bubble.
Attached Thumbnails Any doubters of IC sprayers LOOKS ;)-graph_highlighted_800.gif
Old Aug 23, 2007 | 11:23 PM
hahaha, DYNOmite!!!
Old Sep 27, 2007 | 06:13 PM
dreamweaver's Avatar
perhaps another case of uncorrected or miss corrected ambient air temperature.... Thats what happeed to my dyno numbers back in Jan.
Dallsinghjr1
Sep 17, 2023 11:25 AM
blueslatebenny
Sep 23, 2015 01:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
3-fity
Apr 14, 2012 06:32 PM
