building your motor.....
Old Sep 4, 2007 | 07:14 AM
Audible Mayhem's Avatar
on the other hand though, you had your father, who is a mechanic, if you had any questions. plus you have done a lot of your own work in the past.
definitely not an every day persons chore to pull out their engine, disassemble it, have machine work done, blueprint the entire bottom end, check piston to head clearances along with cylinder wall to piston clearances, file fit the rings down to .001th of an inch, have 4 of each of the 8 different size bearings and 8 different half size bearings, check all the proper bearing clearances down to .0005 of an inch, and check the valve lash on the cam/bucket clearances on the way back up...
definitely worth the money to have it done right...
Old Sep 4, 2007 | 11:28 AM
2slo2bfurious's Avatar
touche! Good point to mention, as easy at it seemed to me with my resources, my ASE master Tech Dad for advice, my local machine shop that has been rebuilding all kinds of motors since the 60's, and Jeremy around the corner for all his tips and advice.... this isn't for the weak of heart. It is always good to have a shop that you can rely on to fix any problems and issues that come up (which will more than likely come up) and just making the whole process quicker with a better piece of mind. So yup it is money well spent if you do decide to have someone else do it for you.... just gotta make sure you pick the right shop!
Old Sep 4, 2007 | 04:38 PM
JDM7672's Avatar
well i will be taking it to a shop to do the install. but would all the parts that i listed would be safe on stock internals if i dont go over 400hp
Old Sep 4, 2007 | 05:56 PM
superchargedg's Avatar
Yes.
Old Sep 4, 2007 | 08:11 PM
ttrank's Avatar
Grocery getter
Yes that is a very nice list. Together with a good tune you will have a lot of fun. Also the fuel return is not needed for ~8psi 400whp. I ran my car without one for many months and just put it on not too long ago because I am going for more boost.
Old Sep 4, 2007 | 10:39 PM
here it is the list of the things that I have that is going in the car
-greddy tt kit
-utec w/ 4map sensor
-hks exhaust
-AAM fuel system
-hks BOV (2)
-defi gauges (boost,oil,egt)
-walbro fuel
i could make that a very very fun car for sure!!!
Old Oct 13, 2007 | 02:36 AM
DAGALEAG35's Avatar
Im About To Do My Motor Pretty Soon....im Getting:
1)je Pistons
2)darton Sleeves
3) Eagle Rods
With A Stock Head For Now But Maybe Might Change My Mind....with A Garrett Gt35 Turbo....tuner Told Me It Would Be Around 5-600 Whp....spending Less Than 12000 ...everything Turbo Kit, Installation Of Internals And Kit.. Plus All Tuning...its A Good Price...ill Be Able To Push 20 Psi Minimum...and I Dont Know About The Higest Yet...
Old Oct 13, 2007 | 04:52 PM
sharif@forged's Avatar
1)je Pistons
2)darton Sleeves
3) Eagle Rods
um...who, may I ask is your "tuner". His estimate of the cost isnt even remotely close to what this should cost...unless its a VRT special.
Old Oct 14, 2007 | 03:05 PM
be carefull man, that deal is too good to be true for sure....
1)je Pistons
2)darton Sleeves
3) Eagle Rods
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
9tray turbo
Sep 29, 2015 10:22 PM
ncg35guy
Sep 24, 2015 04:53 PM
