Beginning Stages of the ATI procharger on my 04 coupe 5AT!!
Old Nov 25, 2007 | 09:57 AM
  #91
waijai's Avatar
i.love.gold
From what I understood from the tuner when it was explained. The G35/350Z has a few timing maps it runs. If it senses knock, then it runs one timing map while in closed loop mode. If he's boosted and tuned on that timing map, all is well. Fast forward a few days/weeks/months down the line. The car doesn't sense any knock anymore and reverts back to the no knock timing map which is more aggressive. That is where the problems occur, since the EU is a signal modifier which works by taking a signal and changing it in some way. That is the nature of a piggyback. For example, the signal from the Mass Air Flow is normally a voltage from 0-5 volts depending on the amount of air entering the engine. The ECU can be tricked into injecting more or less fuel by modifying the air flow voltage. At 5500rpm on g35man04's dyno, the MAF was being maxxed out at 5volts, so it was causing issues w/ the tune.
*again this is what I understood from the tuner, and not my own personal assessment*
Old Nov 25, 2007 | 10:05 AM
  #92
waijai's Avatar
i.love.gold
Does GReddy offer a MAP sensor to use with the eManage for speed density fueling?
Old Nov 25, 2007 | 10:58 AM
  #93
g35man04's Avatar
CLUB MODERATOR
Originally Posted by zazaracing
dont get UTEC man the EU can do much more than UTEC you can get more power than that no problem. Im running ATI with EU and im 408 at the wheels with 8psi.
How you getting so much torque dude?
i think my torque was wrong...i cant remember off the top of my head.....
Old Nov 25, 2007 | 10:59 AM
  #94
g35man04's Avatar
CLUB MODERATOR
anyone know the answer to this?? Please let me know if you do....because in the post before this one wil explained it perfectly as to what is occuring.....
Old Nov 25, 2007 | 11:03 AM
  #95
g35man04's Avatar
CLUB MODERATOR
here is what my e-manage has on the side will....
Old Nov 25, 2007 | 01:00 PM
  #96
waijai's Avatar
i.love.gold
a little searching turned up part #'s
16401301n - sensor
16401406n - harness
I would wait for others to confirm if this is really what you need to bypass the MAF restriction.
Old Nov 25, 2007 | 01:58 PM
  #97
g35man04's Avatar
CLUB MODERATOR
okay will do.
Old Nov 25, 2007 | 02:13 PM
  #98
zazaracing's Avatar
Team Transport Member
Yes Greddy makes the sensor but for what he's running it shouldnt be an issue. I have just about the same setup and getting 408hp and 373tq on a Dyno pack.
Im not maxing out my voltage but I was maxing out injectors in the begining so I had to get 440cc.
Try an ECU reset before you retune. It doesnt sound right but then again nothing on these damn cars ever does what its suppose to. Does your tuner know what he's doing, as far at the EU?
Old Nov 25, 2007 | 02:16 PM
  #99
g35man04's Avatar
CLUB MODERATOR
as far as I know cameron is very knowledgeable in both Greddy and UTEC. He was very helpful in explaining the 2.....i wish he would be able to chime in and explain.
Old Nov 25, 2007 | 02:22 PM
  #100
zazaracing's Avatar
Im not saying he doesnt knwo anything but its hard to trust tuners these days... Some of them read a book and they think they know all.
Just doesnt make sence when your not boosting so much. Like I said though every motor is different they dont all run the same.
good luck dude Im sure its something small and will be worked out soon. Its always something small thats over looked
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
TWASkyliner
Aug 1, 2015 11:43 AM
socalg35x
Jul 28, 2015 10:42 AM
Frostbite91
Jul 27, 2015 05:25 AM
bickfordbft
Jul 20, 2015 07:57 PM
