DIY single turbo build write up
Old Jan 14, 2008 | 04:45 PM
  #136
accordfreak's Avatar
Originally Posted by Good & Tight
Hope you all enjoyed the writeup, it was fun for me and cant wait to see how it performs once it's tuned.
Thanks for all the replies negative or positive.
Regards
Otis
RapidSpool Technologies
congrats!!
Old Jan 14, 2008 | 05:01 PM
  #137
Tonys-G's Avatar
I have seen a couple of cars with a 90 degree bend in the front for ther air filter. I always thought this was a better way to go then the filter righ ton the front of the unit, which would look like it would be a bit@h to get to
Old Jan 14, 2008 | 10:00 PM
  #138
Dsskyline's Avatar
Nice!!!
This is what I have for my intake filter on my custom GT35R kit.
The piece they used has the FPR leaning on it.
I think a piece like that should work for you I think you will have more room than me.
I don't think your turbo inlet is as big as mine which I think is 3 or 4in.
The only thing I dislike about it is that you have to pull back the fender wall and or remove your wheel (I have 20in) to service the filter.
Just in case anyone is wondering my A/C line and grounding wire has been re-routed since it was very close to the hot side.
I strongly suggest you wrap yours also because it will melt.
Good luck!!
Attached Thumbnails DIY single turbo build write up-random-pics-60032-copy.jpg   DIY single turbo build write up-random-pics-60025-copy.jpg   DIY single turbo build write up-hin-085-copy.jpg   DIY single turbo build write up-eternal-st-kit0014-copy.jpg
Old Jan 14, 2008 | 10:25 PM
  #139
Good & Tight's Avatar
Originally Posted by Dsskyline
Nice!!!
Good luck!!
Nice setup, your turbo sits back a little more than this one.
The inlet is 4". Picked up a 4" to 3" reducer today so hopefully it will work with a little cutting.
The down pipe is wrapped and the A/C line is not touching it so it should be o.k
Old Jan 14, 2008 | 10:29 PM
  #140
Dsskyline's Avatar
Cool.
Are you going to do something with the line that is zip tied under the hot side?
Old Jan 14, 2008 | 11:04 PM
  #141
Cool.
In the pic it looks closer than it actually is, also all the exhaust piping is wrapped to keep under hood temperature down. I will add some extra heat shielding for added protection.
Old Jan 15, 2008 | 04:24 PM
  #142
daxxkid's Avatar
Wow looks great, very nice work by the way. Did you end up getting the total for us yet? Very curious about how much it was. Thank you again for such a great step by step.
Old Jan 15, 2008 | 04:25 PM
  #143
daxxkid's Avatar
  #144
daxxkid's Avatar
Old Jan 15, 2008 | 08:55 PM
  #145
panda007's Avatar
Great DIY! I hope it works out fine!
Now, someone post up a DIY for built engine blocks. :P
DIY is NOT wrong... I'm sure people rather would pay to do all this butt-load of work. I installed my own APS TT and don't want to do that **** again.
Old Jan 15, 2008 | 09:01 PM
  #146
Adon's Avatar
I think the cheap chinese turbine is gonna be the downfall of this whole project. All the work you put into this looks really good but you yourself said that you tried convicing the owner not to cheap out on the turbo.
Old Jan 15, 2008 | 09:02 PM
  #147
Made the intake piping today. Had to cut to make room and bought a short air filter.
Well my job is officially done on this car, the owner picked up the car today and is getting it tuned this Saturday,Utec map sensor and injectors by someone who posted in this thread.
Total spent on parts $1413.93.
Old Jan 15, 2008 | 09:17 PM
  #148
GreenGoblin's Avatar
The goblin resurrection
wow your in Davie, so am I we need to hook up so you can see some of the projects that we have in the works.
Old Jan 15, 2008 | 09:45 PM
  #149
Shoot me a PM.
Old Jan 15, 2008 | 10:27 PM
  #150
daxxkid's Avatar
Just wondering, what do you do for work, if you don't mind me asking, that is a very well done kit. Will you know how it will do after it gets tuned? Let us all know if you can.
Thanks
