air bag on with turbonetics and utec
Old May 27, 2008 | 09:20 PM
03coupe's Avatar
Has anyone had there air bag light come on after installing a Utec. I did the whole install myself and double checked the wire's behind the glove box and they seem to be ok, I also unplugged the battery over night and still unable to get the air bag light to go out. Could the utec be doing this ?
Old May 28, 2008 | 09:37 AM
6spG's Avatar
Double check the yellow wire/connector that is attached to the glove box.
Old May 28, 2008 | 01:02 PM
03coupe's Avatar
Tried that but had no luck
Old May 28, 2008 | 03:21 PM
G37Rider92649's Avatar
yikes i suggest you just take it to someone who installed utec many times, even when my utec was installed at a dumb shop the first time, the tuner even tuned it after un-grounded, 30% use of the utec only during tune, i was detonating at high rpms too, piece of sh*t, i personally hate utec too but yeah take it to someone who installed it before, i mean unless you got it already, then for sure! good luck
Old May 28, 2008 | 03:56 PM
6spG's Avatar
Don't think it has anything to do w/ the Utec. I installed my kit w/ Utec and didn't have a problem. You could try removing the Utec to see if the light goes out.
Old May 28, 2008 | 05:11 PM
ttrank's Avatar
Grocery getter
UTEC has nothing to do with the airbag.
Do the key reset procedure and see if it comes back.
KruZZe
Feb 27, 2023 05:04 PM
KallDay86
Jan 8, 2016 12:42 AM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
