STS turbo successsssss!
Old Sep 14, 2008 | 10:17 AM
  #61
G35Ian's Avatar
that is a pretty sick setup...If I went turbo that is what I would get.
Congrats and best of luck with your STS
Old Sep 14, 2008 | 12:13 PM
  #62
6spG's Avatar
I installed this kit in my garage. I was a little frustrated in the beginning (STS sent wrong parts) but in the end I am happy w/ this kit. Like FI’ed G already stated, this kit is great for under 10psi (400whp).
As far as clearance, it’s not an issue for me. I’m lowered on 350Z H-techs and have no problems. Here are some pics that show the clearance:
1. Camera at ground level
2. Sitting at ground level
3. Kneeling on ground.
Old Sep 14, 2008 | 01:48 PM
  #63
G37Rider92649's Avatar
Originally Posted by ttnissanzx
that dyno sheet still looks scary to me man, how your lines go at high rpms, and your air fuel doesn't look perfect. I don't know, I don't know much but by judging my opinion from many dynosheets I read personally, but again, great set up, this is one unique turbo set up. I wonder what happens if you scrape while leaving a plaza/ going up a speed bump or something
Old Sep 14, 2008 | 02:07 PM
  #64
FI'ed G's Avatar
The Dyno operator didn't put any smoothening on the graph (0) so that is why it is ugly. There are many shop who like to run around 12.0-12.2 A/F and there is really nothing wrong with that as long as the timing is conservative and the car is not knocking... Rich best torque is around 11:5 and Lean best torque is around 13.1 (I think) and that is why many shop tune in the middle around 12.2 A/F. Most shop run around low 11's because they want extra safety and are willing to sacrifice power. Like the OP said the shop said his tune is the most Optimal but the problem is that he doesn't have that much room for error...
Look at 6spd pix, the piping is not even the lowest point of the car.... even the lowest point of the charge pipe is in between the rear axle so there is no way you'll scrape that coz your rear wheel will not let it happen..
Old Sep 14, 2008 | 02:23 PM
  #65
JOKER's Avatar
CLUB MODERATOR
how safe is this in the rain?
  #66
Ahhh I seee..interesting..
Old Sep 14, 2008 | 03:02 PM
  #67
FI'ed G's Avatar
Not a problem.. driven the car on one of the hardest rain you can think of and was fine...
Old Sep 14, 2008 | 03:34 PM
  #68
vq35dedriver's Avatar
How long was the install? Is the kit compatible for the 5AT? Where can I purchase and how much?
Old Sep 14, 2008 | 04:55 PM
  #69
FI'ed G's Avatar
Just call STS directly and try to bargain with them. There is nothing different between AT and MT kit, just make sure get the G35 version.
Also you can email this guy and tell him a fellow from my350z gave you his info.. see below.
Originally Posted by Boozt
Talk to Joe at STS and tell him I referred you (Jim Earle Silver 2003 350Z). I just talked with him on price....5195.00, However this may only be for a Z and not the G???? Email joe@ststurbo.com and mention my name...see what comes up. -Jim.
Are you going to install this? if not then I suggest save about $1400-$1600 but this is with a Full Tune already, for just install then I say about $1000-$1300... Depend really what your shop hourly rate is. There are members here and my350z who did their own install like 6spd but you have to be patient.
Old Sep 16, 2008 | 08:52 PM
  #70
2drwild's Avatar
HMMMMM sWEET setup..Can you post pics of the entire system?
Old Sep 17, 2008 | 01:42 AM
  #71
G35pm's Avatar
How do the oil for the turbo work? I see lines along the piping. Is there a pump on the return line?
Old Sep 18, 2008 | 09:15 AM
  #72
6spG's Avatar
The kit comes w/ a two speed oil pump.
Old Sep 18, 2008 | 11:29 AM
  #73
WhosUrBuddiee's Avatar
What else did you have to buy to support the kit? Fuel pump? Injectors? Gages?
Old Sep 18, 2008 | 11:59 AM
  #74
FI'ed G's Avatar
Kit comes with everything..
-Turbo – TO4E60 O Trim .58 AR housing 520 Crank HP turbo
-Spark Plugs – NGK One stage colder
-Injectors – 440cc
-Intercooler – Front mount air to air
-BOV - Tial 11 # spring below 4000 feet
-Waste Gate – Tial 38mm .4bar spring unless order different
-Tuning/EMS – UTEC tuning with MAP-
-Oil – STS patented 2 speed oil pump with lines and check valve
-PCV – STS patented PCV crank case boost eliminator with lines
-Wire – STS Multi role wire harness with optional meth pump connection
-Pipes – STS HPC coated inside and out charge pipes with high pressure silicones and clamps
-Bolts – STS 350Z/G35 bolt kit
-Fuel- Walbro 255lph fuel pump.
Of course clutch and gauges is not included... No Turbo kit will include gauges..
Old Sep 19, 2008 | 07:31 PM
  #75
ttnissanzx's Avatar
ran the 1/4 mile yesterday. was dissapointed. located here in FL ran at bradenton a best time of 13.303 @ 108. i really thought i'd break the 12's but nah... way off. the trap speed is good though. i just gotta get better launches and 1/8th mile times. 2.150 60ft and a 8.84 at 84mph. in the eigth
