My little build with the new Vi-PEC EMS.
. its not something that really thought about until the methanol was spraying out
Well i took a bit of break from the car for my sanity and my wife and kids needed some QT since the majority of my evenings and weekends this summer have been spent wrenching.
I am a drilling fluid supervisor......its hard to explain but I go out to oil/gas drilling rigs and they use a fluid to drill with and I do a bunch of chemical tests on the fluid and advise the oil company on what chemicals they should add to the drilling fluid to optimize it.
A
Getting ready to install the engine
Engine in
adding the Evans NPG-R
So where am I at now? I have everything installed and the car runs, but i have an exhaust leak I have to chase down then onto the dyno!!
Engine in
I doubt the L19s would thread into 1/2" holes very well and HKS dose not make a large enough bore gasket...I will just go with the cometic gaskets that I got cut for the 1/2" studs...the ones that are in the car now
ATI although I have no real reason why I picked that one, i told my tuner i wanted a Fluidamper or ATI he got me the ATI. He said he uses them the most and has never had an issue with them.
Well it has been snowing here for the last few days
but yesterday i got the car out for a couple hours. The drivability needs some work but the car also has gas that is close to 6 months old. The WOT is great I havent got on it too hard yet
I have no leaks but one IC pipe keeps popping off so when i was putting it back on last night i noticed the clamp is bent
so i plan to change that out tonight get some fresh gas...then go see if I can find some trouble
I have a few friends already planning some shennagins one with a evo9, the other with a nissan GTi-R so i might have to see if I can keep up with some of the AWD boys from a dig
with temps near freezing traction will suck but the car is a monsTTer in the ice cold air.
