im going nitrous, need some help..
Old Nov 18, 2009 | 08:52 PM
liche's Avatar
1. Get 1-step colder plugs
2. Tap your RPM right off your injector. The G35 service manual will tell you which wire color to tap off from) - I think you can download it free if you search for it (PDF)
3. For 100-shot and over, you'll need to pull some timing. Uprev Osiris is a low-cost alternative for custom tuning to a full-up piggyback ECU.
and number 4 . . .
4. Check to see if you need a permit for Nitrous or not. Some states require a permit to purchase and besides it costing money, it can take a LONG time to get (1-2 months)
Old Nov 18, 2009 | 08:56 PM
TTG35forT's Avatar
Pull the plugs and check them. If they look OK mechanically, then check there color against a suitable chart. There are a lot of charts available that you can find with a Google search that will show you what is normal, what is rich, and what is lean. If you are running too rich, one or more of the plugs may be fouling out.
Old Nov 19, 2009 | 10:55 AM
g35rida's Avatar
would it be that v-power new bull .. im about to go and get the iridium ones change it all over.. because this is driving me crazy. they told me that the v-power isn't good for our cars. is this true. wat should i do im not going nitrous no more. to much ecu hasel.
G35VSHNG37
Sep 10, 2015 01:54 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
SoCalTed
Forced Induction
37
Oct 7, 2004 11:53 AM
infidsg35
Apr 7, 2004 03:08 AM
zaid918
Mar 19, 2003 10:02 PM
