APS Extreme Twin Turbo Build
Old Oct 20, 2013 | 06:41 AM
  #151
o__O's Avatar
Originally Posted by Babyseat
Love the build hope your still enjoying it
Yes she still puts a smile on my face everytime I take her out!
Old Mar 7, 2014 | 05:29 PM
  #152
o__O's Avatar
Buttonwillow track day on March 1st. Nitto NT05s proved to be a poor tire choice in the rain. Couldn't get them hot enough to get much grip. Still had a lot of fun though! Enjoy the pics...
Old Mar 7, 2014 | 07:09 PM
  #153
herrschaft's Avatar
^Sounds like fun. I'll come out and play when I eventually get my car put back together.
Old Mar 7, 2014 | 08:59 PM
  #154
TxPwnBoy's Avatar
great pics
Old Mar 7, 2014 | 10:02 PM
  #155
Urbanengineer's Avatar
Holy ***** thats awesome. Still snow on the ground here.
Overall opinion of the NT-05's? I imagine its hard to keep 500 whp tamed.
Old Mar 8, 2014 | 10:16 AM
  #156
o__O's Avatar
I ran no more than 8 psi. Couldn't push it in the corners...and even in the straights I was losing traction!! Felt like I was driving on black ice. Aside from the NT05s I just put in eibach sways and powergrid end links. The suspension does need to be dialed in and a corner balance is in order.
Old Mar 14, 2014 | 10:32 PM
  #157
o__O's Avatar
https://www.facebook.com/wedehase
Old Feb 11, 2015 | 01:35 AM
  #158
o__O's Avatar
melted cam position sensor & plug
During some routine maintenance I discovered the wire harness clip for the driver's side cam position sensor melted. I managed to track down a new clip and bought a new sensor. But does anyone know how to de-pin the old clip? Trying to avoid cutting and splicing in the new clip.
Old Feb 11, 2015 | 01:53 AM
  #159
drifterxG's Avatar
Well that's unexpecting! I think splicing and soldering is best unless you can find a clip that matches.
Old Feb 11, 2015 | 01:56 AM
  #160
o__O's Avatar
Here's the link in case others need the same clip for any reason
http://www.wiringspecialties.com/vqcamsecogr.html
Old Feb 11, 2015 | 03:42 PM
  #161
Cux350z's Avatar
pop the white piece off with a small flathead.
Look down into the pin hole from the sensor side. (not the wire side). You should see the plastic piece that snaps down to hold the metal pin in.
Take a very small allen key with a ball end and stick it in the hold and pivot the plastic piece up. Only takes small force. Pull the wire back at the same time.
Its very easy once you get the hang of it. Hard to describe.
Old Feb 12, 2015 | 12:03 AM
  #162
o__O's Avatar
Thank you!
Old Feb 13, 2015 | 11:56 PM
  #163
o__O's Avatar
E85 users...
This is damn scary. Afr was starting to show a lean condition. So I pulled the injectors and was shocked
I sent them out to be cleaned
Once I had the injectors back I started looking around it seems this issue was somewhat common. And it seems the remedy is to occasionally run pump gas or an additive like seafoam. Anybody else have this happen? ?
Old Feb 14, 2015 | 03:36 PM
  #164
N8Deezy's Avatar
Yea kinda when I converted to e85 the guy said to make sure to run 91 at least once a month because that could happen. He deals in subies and evos and said its a common issue wit e85. So whenever my afr show any sins of leaning I'll run a couple of full tanks thru with 91. So far so good for the last 2-3 years
Old Feb 20, 2015 | 01:29 PM
  #165
drifterxG's Avatar
Out of curiosity, did you get CEL codes? Mine just threw P0304 indicating cyl 4 is misfiring. I think one of my oem injectors just went bad. (Trying to keep this motor alive while my motor is being built.)
