"Service Engine Soon" light
Old Feb 27, 2005 | 06:19 PM
PearlWhite03's Avatar
It's been about 3 weeks since my Greddy TT kit was installed along with the FMIC and exhaust. Yesterday the "Service Engine Soon" light came on and it has been on all day. I am assuming that it is just an emissions thing ( I still have my cats in though), but I do not have an OBDII scanner to verify this. Has anyone else had this happen?
Old Feb 27, 2005 | 07:15 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
I bet an o2 sensor went bad...did you install include and removal of the stock cats or o2 sensors from the exhaust manifold?
Old Feb 27, 2005 | 08:26 PM
Draco24433's Avatar
I just installed an ATI procharger with stock exhaust manifolds and have the same problem. When I hooked up the scanner it said that I was running rich in bank #2. When I did my dyno the A/F mixture read at 11.7 accross the board. My mechanic told me the light comes on because I have the stock exhaust so I order some crawford high flow cats and that should fix the problem. I hope this had shed some light on your problem. good luck.
DJ
Old Mar 1, 2005 | 10:08 PM
jgsm's Avatar
Many different reasons can cause the SES and it will make the engine run very rich. You definitely can't ignore it. I think the first place to look is your MAF sensor and A/F ratio.
Allen
Old Mar 5, 2005 | 11:29 PM
I had it checked out and its a PO455-EVAP emission control leak. It is in the exhaust somewhere, I think right by the muffler on the passenger side exhaust where it bends above a sway bar or something.
Old Mar 8, 2005 | 08:23 PM
gersteinp's Avatar
Be sure your gas cap is tight. If it isn't and you tighten it (at least 2 clicks), it will take three starts and normal runs for the light to cancel. Or you can cancel it with the gas pedal technique (easy).
Old Mar 9, 2005 | 11:46 PM
Yeah, it's definately not the gas cap, tried that numerous times plus filled up couple times as well. I just need a weekend off to crawl around under the car.
Old Mar 10, 2005 | 09:00 AM
neffster's Avatar
Good luck with the fix. Did you go to Racing Zone to get the reading or did you have to go to Orlando Infiniti? What's your opinion on Racing Zones installation? Did you have any problems?
Old Mar 10, 2005 | 09:26 AM
TINMAN's Avatar
this is a very common problem with FI cars.mainly because almost all kits are smog illegal.the sensor detected and let you know that something is not right,need to take it to the dealer.don't worry about it.from what i know,it will eventually goes away after so many times of turning the engine on and off.another word the code will reset itself sometime later.my car turboed 3 months ago and that light came on twice.both time it gone after few days by itself.i notice both time it went off after WOT.it sound stupid but go drive the car and drive it hard.good luck.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
derres
Aug 28, 2015 03:27 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
mjfenix
Jul 17, 2015 02:07 PM
