Vortech rattle at idle???
Old Sep 14, 2005 | 11:07 PM
  #31
G352NV's Avatar
Never enough
I wouldnt listen to anything Vortech has to say. When I called I felt like I knew more then them! Just loosen the belt and raise the idle.
Old Sep 30, 2005 | 07:55 PM
  #32
SIN3's Avatar
i had the same problem, and i thought it was a loose bearing so i had my shop take off the blower and ship to vortech. they said it was fine and it still makes that noise at low idle i think i am going to raise my idle. good luck
Old Oct 8, 2005 | 01:13 PM
  #33
SFLG35's Avatar
FGC President
Hey guys...I'm trying to fix G8tor20's rattle. Can someone explaint to me exactly how much to lossen the slider bolt. We have moved it down to where there is an inch to play on the bottom of the cog belt, but, it still rattles....and more annoying b/c its rattling intermitingly and not a steady rattle...if that makes sense. Lemme know what you guys did to find that "sweet spot".
Old Oct 8, 2005 | 02:14 PM
  #34
gersteinp's Avatar
Slap on two wrenches--one open end and one box end (the one you're going to pull up on). Let the car idle and then gradually tighten the belt until the noise is minimal. If you overtighten, the rattle gets louder and nastier sounding. You can't completely eliminate the rattle when the idle is down under 650 or so--but who cares? It's not going to hurt anything.
seagrasser
May 3, 2022 09:43 AM
Thebaws11
Jul 2, 2021 11:36 AM
vamarris
Sep 26, 2015 12:56 PM
Jnm07
Sep 5, 2015 01:16 AM
n2fooz
Sep 4, 2015 07:46 PM
