stillen supercharger will be installed
Old May 6, 2006 | 06:59 PM
  #151
codeflux's Avatar
sigh... you guys make me want to get Turbonetics single turbo. sigh...
Old May 6, 2006 | 09:15 PM
  #152
ttrank's Avatar
Grocery getter
Do some serious research before you go TN. You can get big #'s but there are a lot of issues with that kit.
Old May 7, 2006 | 03:29 PM
  #153
sentry65's Avatar
question for the stillen guys - how much boost does the stillen make at different rpms?
does anyone have a boost gauge? What boost does it make from 1000-6600 rpms?
I've been hearing it makes 3psi at 1000 and then rises at 6 or 7 psi to redline - is that true?
Old May 7, 2006 | 05:57 PM
  #154
nate4598's Avatar
I can't really tell you @ what rpm makes what psi but when I'm at WOT, I know that I already @ 8~8.5psi b4 redline...I'll test it out let you know
Old May 7, 2006 | 08:17 PM
  #155
sentry65's Avatar
you have a boost gauge I'm assuming? or you going to take it to a dyno or something. A lot of people lately where I live (1300 ft above sea level) say that they make around 7.5 lbs of boost at redline - might be the elevation though
Old May 8, 2006 | 02:39 AM
  #156
nate4598's Avatar
Yes, I do have Defi boost gauge...but I'm sure I'm hitting at least 8 b4 redline though
Old May 8, 2006 | 04:01 AM
  #157
sentry65's Avatar
oh you're stage 4, ok that makes sense then
still boost from a stillen isn't interchangable with boost from a turbo or vortech because of different levels of parasitic loss from the design of the blower/turbo. I mean someone could be making 50 psi and still only be making 300whp if the efficiency sucked bad enough for the engine to drive the blower
Old May 8, 2006 | 08:39 AM
  #158
G35_TX's Avatar
You should be making full boost at around 1800 rpm on the Stillen SC all the way almost to redline where it starts to cut back a little.
Old May 8, 2006 | 03:06 PM
  #159
ttrank's Avatar
Grocery getter
No, it does not make full boost at 1800. The boost comes on immediately but keeps trickling up until redline. I will get some psi/rpm estimates the next time I go for a drive.
Old May 8, 2006 | 03:27 PM
  #160
sentry65's Avatar
I'm going to guess it's around 3-5psi at 2000 rpms, up to 7-8psi at redline
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
Team STILLEN
Aug 10, 2015 08:17 PM
LuisGee
Forced Induction
13
Jul 22, 2015 09:15 PM
