Turbonetics Catless and O2 sensor
Old Mar 4, 2006 | 11:26 PM
3.5T's Avatar
Does this kit cause problems with tripping the check engine light? This is day 2 with the kit installed and all seems well except the check engine light came onn tonight. The car seems to working well. Idle cruise and boost all seem to be working properly. Will I continue to get this error because I deleted the cats?
Old Mar 4, 2006 | 11:43 PM
3.5T's Avatar
It was also pretty cold out, maybe around 35 degrees. Does the cold affect the turbo at all?
Old Mar 5, 2006 | 08:42 AM
DP03's Avatar
If you did not put in O2 sims, I would guess you will continue to get the light....
Old Mar 5, 2006 | 08:50 AM
3.5T's Avatar
I didn't put in sims but the the exhaust pipe that the o2's go on, on this kit have the o2s sitting out of the stream of exhaust. Its almost like what others where doing to defeat the SEL with test pipes using the spark plug non foulers to space out the o2s. Maybe they they are not long enough?
Old Mar 5, 2006 | 11:08 AM
3.5T's Avatar
I disconected the negative battery cable overnight to reset the pute. I took off the gas cap and put it back on just in case is was something stupid like that. So, I go out for a 25 mile spirited drive and no SEL. The car is operating great. IF my O2's were tripping an error would it trip right away? In the Turbonetics instruction manual it says that it is normal for the car to smoke and have a strange odor for the first hour or two due to the oils in the pipes burning off. Could that cause an error at the O2's and go away after it is burned away? Any thoughts or ideas.
Old Mar 5, 2006 | 02:35 PM
3.5T's Avatar
Come guys, where are you at? 40+ looks only 1 comment.
Old Mar 5, 2006 | 02:43 PM
636Racer's Avatar
^hah, I would comment but I havent installed mines yet. Are you sure it's your O2 that's tripping the SEL? Did you hook up scanneror did a self diagnostics?
Old Mar 5, 2006 | 02:57 PM
G35pm's Avatar
The smoke and oil burning off the pipes shouldn't give you a SEL. Maybe check the code.
I threw a CEL a couple weeks after i had my kit. Misfire. Reset the ECU and it was gone.
Old Mar 5, 2006 | 03:28 PM
3.5T's Avatar
No I haven't checked the codes yet. I just know of the problems associated with test pipes and since this kit deletes the cats maybe that was the problem. But when I looked at the how the sensors are mounted, they are hooked up just like how others were correcting the problem with the test pipes, by spacing them out from the pipe. The car seems to be running well so I guess I will just have to monitor it but I was wondering if anyone else had a similiar issue after going FI.
Old Mar 5, 2006 | 05:03 PM
MIAPLAYA's Avatar
Check the code and let me know what it is. If its 0300 just disregard it. Most boosted cars get this code.
Old Mar 5, 2006 | 06:14 PM
3.5T's Avatar
You need an obd2 scanner to find out if its a 0300 code? I had a C5 and it would give you the code if you threw one. Our G's don't do that do they?
Old Mar 5, 2006 | 09:00 PM
636Racer's Avatar
do a partial ecu reset and count the number of blinks. do a search
Old Mar 5, 2006 | 10:02 PM
3.5T's Avatar
Cool, found it. The light hasn't come back on but if it does I will try this.
Old Mar 5, 2006 | 11:23 PM
636Racer's Avatar
If you cleared the codes (no SEL) then there's no codes that will come up.
josh.irvine.6
Forced Induction
Apr 27, 2012 10:08 PM
DanielsG
144
Dec 27, 2010 09:55 PM
BlinkerFluid
Archived Sales
19
Mar 24, 2008 09:37 PM
3.5T
Forced Induction
Sep 2, 2006 05:35 AM
