G35 & G37, Coupes & Sedans
Everyone: Check Your Oil!
Rating: Thread Rating: 5 votes, 4.80 average.
  #1726
Old 06-07-2014, 07:46 PM
Lovelylove35's Avatar
oil problem
ok so my car has 220,000 miles and i love my 2004 g35, but at start up i'm hearing a noise, and my oil light flashes, so i put oil in it and then about 3 weeks later same thing! i've relplace the valve covers, the camshaft and crankshaft sensors,so what is the problem???? If anyone has the answer please let me know, i love my car, is it time to give her up??
  #1727
Old 07-03-2014, 01:47 PM
telcoman's Avatar
Originally Posted by Lovelylove35
ok so my car has 220,000 miles ........, i love my car, is it time to give her up??
Yup, time to find another love
Telcoman
  #1728
Old 07-03-2014, 02:27 PM
Texasscout's Avatar
Received 2,116 Likes on 1,768 Posts
Depending on how deep your love is and how you have maintained it (bushings, hoses, belts, i.e. long term maint.) , you might be able to justify a long block. It sure beats car payments.
  #1729
Old 07-21-2014, 08:01 PM
Drifter2090's Avatar
My car is a 04 coupe and it has 105k KM's so 65k miles and it just drinks oil....from being at full oil level, if I go to school and back once our twice (15 km one way) the oil level will go down to be a bit above half. Since I got my oil change (which was 5w30 amsoil synthetic) I have used a full 5L bottle of 5w30 synthetic to just top it off every time it finishes and it has only been 2.5k Km's since oil change. I dont really understand how the car can burn this much with this low mileage, next oil change I will try 20w40 non synthetic and see if it helps, also my exhaust tips get black very fast due to the oil burn.
  #1730
Old 07-22-2014, 08:36 AM
Texasscout's Avatar
Go to dino oil, Castrol 20W50
  #1731
Old 07-22-2014, 09:37 AM
Mr. Brooks's Avatar
I wouldn't use 5 quarts of 20w50 during winter months. The oil is already thick and cold starts during winter months can cause the c.e.l. to come on. Try 3 quarts of 20w50 and 2 quarts of 10w30.
  #1732
Old 07-22-2014, 10:16 AM
Texasscout's Avatar
Well, this is Coastal South Texas where a "cold" day is 45 degrees....
  #1733
Old 07-22-2014, 11:05 AM
Mr. Brooks's Avatar
In South Texas you won't have a problem but, others that see much colder temperatures during the winter will. I tried 20w50 in another car I had and during the winter the check engine light would come on and stay on until I changed to a thinner oil.
  #1734
Old 07-24-2014, 07:25 AM
Well winters are very cold here but I was planning to store this car during the winter because the salt will destroy it. Is 20w50 good till winter comes? or should I use 20w40, or is it not much of a difference? thanks
  #1735
Old 07-24-2014, 09:15 AM
Mr. Brooks's Avatar
Drifter, the "G" isn't bad during the winter. I drove mine through one of the worst winters I've seen in a long time, this past winter. As for the oil, I would use 3 quarts of 20w50 and 2 quarts of 10w40 and see how your oil situation works out.
  #1736
Old 07-24-2014, 04:40 PM
Ya I drove it last winter and it did very well for a RWD car but I hate rust and I see small signs of it on my rear quarter panels, so I will just get a winter beater. Thanks for the help I will try this next oil change, is there a brand that I should use or just any? thanks
  #1737
Old 07-24-2014, 06:14 PM
Mr. Brooks's Avatar
I use Royal Purple in my "G" but, if there's a brand you like stick with it. As for rust try Naval Jelly, it's good for removing rust, dirt, grime, and oxidation off of most surfaces.
  #1738
Old 08-08-2014, 08:57 AM
theron92's Avatar
2004.5 Infiniti G35 coupe 6mt RWD 108,300 miles (purchased at 99,900) is burning a quart of oil in 200-500 miles. Now idle is getting rougher. Idles around 600-640rpm (sometimes drops to 550-580 quickly) and used to be 680-740 range. Coolant level has also been dropping recently. (Head gasket maybe? but could it cause this much oil consumption) Have oil build up on exhaust tips as well.
Put an oil catch can on and replaced pcv and drove 140 miles and am already about .5 quart low. Tried cleaning throttle body, fuel injector cleaner, have k&n filter and MAF is clean no Check engine lights. Just replaced transmission fluid with redline as well.
Had no issue all winter (did see light flash once on a fast stop but had oil change planned for the following day and had no signs besides that). I did run with a bad O2 sensor for a couple months though.
Just bought 0w-40 mobil 1 to see if that helps at all but school is coming up and I cant afford the car to go bad during the school year (commuter). Any advice appreciated. I drive conservatively for the most part shifting at 3000 rpms and downshift when coming to stops but my downshifts don't pass 3100rpms. Occasional spirited driving but haven't really revved hard except for when I was just learning stick and threw it in 2nd instead of 4th and red lined but that was 7 months ago.
  #1739
Old 08-08-2014, 03:32 PM
Mr. Brooks's Avatar
I would switch from 0w-40, to a thicker oil 3 quarts 20w-50, 2 quarts 10w-30. Also with your mileage I would check compression and also check to see if oil is getting past the piston rings. As for the rough idle check your spark plugs for oil soak.
  #1740
Old 10-08-2014, 02:19 PM
Gomer's Avatar
So I know that this thread has been inactive for a while but I am looking to fix the problem at least as best as I can. So I live in Charleston, SC. I was going to change my oil type to 10W-40. I was also going to put an oil catch can on the engine. In order for this to be most effective, it needs to be a baffled catch can, yes?
Thanks for the help.
03.5 Sedan 149,000miles
You have already rated this thread Rating: Thread Rating: 5 votes, 4.80 average.
Quick Reply: Everyone: Check Your Oil!
