Everyone: Check Your Oil!
#1786
Hey guys, i just recenly bought a 06 g35 coupe and while changing out my spark plugs i had noticed that 1 of them had some oil at the bottom of it (where you get the spark) i asked a couple of places and they all keep telling me different things like valve cover, spark plug seals,combustion chamber, did anyone of you guys have this problem?? if so please help me on how to get it fixed...
I have the long-block replacement from the very first oil consumption TSB. She burns about a quart every 5K miles which is my usual OCI so that's acceptable to me. My original 2006 Revup burned a quart/~23 hundred mi brand new.
I run a catch can and get about .5qt out of that every OCI; PCV valve is always drenched and doesn't rattle, so i clean that every time when I drain my catch can. I also religiously use a fuel additive to help prevent my oil rings from getting stuck which IMO, helps any engine in and/or prevent oil consumption with a lot of miles on the clock.
Enjoy your 06. I still love mine and wouldn't trade it for the world.
#1788
#1789
I drove ttrank's car solo
Received 1,487 Likes
on
Erick please follow my direction to your other exact same post. Search the forum and you'll find a ton of threads that address both of your questions. If you post these questions again you might get hit with an infraction for not following the forum rules and I don't think you want to start off that way here.
#1790
This place is dead enough now, 75% of the posts here are vendors. Lets run off the newbies, that will help a lot. Yes, he should search, however the search function here suks donkey ***** and you guys know it.
Search: Best oil for VQ35
Search: Best spark plugs
Steer him in a general direction, give him a few clues on where to go or this place will turn into a dead vault of information that nobody uses.
#1791
I would recommend using 10w30 synthetic in the winter months and 10w40 in the summer months. Not sure of the part number but I have always used NGK's in all of my cars.
#1792
Oil check
Saw your other posts in this thread. If the engine was starved for oil -- you did say the light came on -- then it doesn't take long to cause extensive engine damage. All the bearings, pistons, cams, etc can get damaged from lack of proper lubrication.
Never had a problem with mine so far.
Man, every car I've ever owned I make it a point to check the oil very often and get a feeling for how much oil the engine uses so it doesn't run too low on oil. No faster way to smoke an engine than with a super low oil level.
It sounds like the Service Rep knows it was ran low on oil and that's why they are refusing to cover it under warranty. Hope you get it fixed
#1793
Texasscout (07-24-2019)
#1796
Received 2,473 Likes
on
Coupe 6MT Premium RAS
Yes you won't hurt a thing on this engine if you mix dino and synthetic.
However this only applies to engines that were DESIGNED for conventional oil, if the engine was built around blend or synthetic then you CANNOT mix in a quart of conventional unless it's a dire F'n emergency. And if you do then you should keep rpm's below 4k and drain out the conventional/refill with blend/synthetic (whatever it was engineered for) as soon as possible.
#1797
on
#1798
on
#1800
on
Blue Dream (07-29-2019)
2_Liter_Turbo
01-19-2018 01:48 AM
Bean_VQ35DE
49
08-03-2015 05:17 PM
