Everyone: Check Your Oil!
#1698
That's what most manufaturers call "normal". Back in the middle sixties, the dealers would say 1 quart in 1000 miles was "normal". I say 1 quart in 7500 is acceptable, more than that and you need to start checking it weekly.
#1699
#1700
A good engine, like my three Hondas use "ZERO" oil or close to that all the way to 100,000 miles, in between oil changes.
My G35 was like that until 26,000, when suddenly it started drinking oil.
All my attempts till last oil change, last month were futile, the last one is very promissing!
I wil wait till 1000 miles minimum before offering my solution, if it works.
#1701
so i believe i am a part of the OC club my car smokes under hard accelaration....its blue smoke so i know its burning oil...i bought the car from a used car lot, however it onl has 30345 original miles, i know its been over 6 years so definately dont have warranty, what can i do? its a 04 5at, not sure if these models came out with that issue though, any help appreciated
#1705
#1708
#1709
Mine formed a rod knock. Consumption was about 1qt to 1.5 every 3k. Then it started getting a slight knock which seemed to make it consume more. But the Bulletin says do the motor if you still hear noise after its topped off so I will never know. At the dealership now getting inspected for sludge. Extended nissan warranty and their rules. Good thing I use synthetic every 3-3.5k miles should be spotless.
#1710
