G35 & G37, Coupes & Sedans
Everyone: Check Your Oil!
Old Mar 1, 2007 | 06:19 PM
  #526
accordhybrd's Avatar
Originally Posted by shdowflare
For the past four days I've been checking my oil each morning after the car's been sitting all night (since the oil level is almost impossible to read otherwise), and putting in a quart before starting the car when I didn't see any between the H and L.
Finally this morning, four days and four quarts later, I finally see the oil mark again just above the L. I don't know if any engine wear/tear occurred but I'm sure it's not out of the question. So now I'd like to troubleshoot to see whether any damage has been done. A buddy recommended testing each cylinder for compression to make sure they all:
a) have the same compression level.
b) are in accordance with factory compression specs.
Do you guys know any other way to check for potential engine damage due to low oil?
And I've also heard that oil burning can be caused by a few things, one of which is bad piston rings. Is there a way I can diagnose the root cause, be it the rings or otherwise?
Thanks all,
B
You could also do a leak down test.
Old Mar 6, 2007 | 12:28 AM
  #527
JDeuce's Avatar
I'm new to the G scene and have been reading through this thread (and what a long thread it is....). Are there years (or engines) that are more prone to the oil consumption problem? I've read that the "Rev Up" engines don't have the problem? What are Rev Up engines and when were they produced?
I'm currently running an 04 G coupe w/6MT. Since first reading the thread I've been checking my oil fairly reqularly.
This is somewhat disheartening considering the fact I had a '97 Acura CL 3.0 since it was new (which I traded in for the G) and NEVER had to add oil to it. Of course it wasn't as exciting a car as the G but I never thought part of the excitement of owning one was having to worry about the oil consumption.
Old Mar 8, 2007 | 02:23 PM
  #528
ResIpsa's Avatar
It's the REV Up engines that have the problem. This engine is in all 2005 and 2006 6MT's.
Old Mar 8, 2007 | 02:43 PM
  #529
Reggie01se's Avatar
what about 07's? i just picked up my 07 on monday, and ive been checking the oil, but the dipstick is completely retarded and i dont know if im getting an accurate reading. hopefully this doenst affect 07 6MT's.
Old Mar 8, 2007 | 08:31 PM
  #530
JDeuce's Avatar
That's good to hear.
Thanks
Old Mar 9, 2007 | 02:02 PM
  #531
EZZ's Avatar
EZZ
Originally Posted by G_XXXV
I have an '06 6MT Coupe with 13K miles and started noticing my oil level decreasing even before my first oil change at 5k miles.
When I did the first oil change, I was amazed at how little oil came out...there was maybe 2 quarts in the pan. At first I thought the remaining oil was trapped somewhere in the engine because the front of the car was on rhino ramps. But that wasn't the case. The car had consumed the other ~3 quarts.
Now I check the oil at least once a week and am very concerned over the whole thing.
BTW, was a poll ever created on this site?
Thanks,
Kevin
Is a poll even necessary anymore? If you have a rev-up, you are susceptible to oil consumption
Old Mar 9, 2007 | 03:33 PM
  #532
V35 Skyline GT's Avatar
6MT Coupe
Don't mean to be the bearer of bad news, but I just got service done on mine, told them my consumption has mellowed out and the service consultant told me (as he pointed to a 07 coupe loaner) that one using about 1qt/1000mi too.
Kevin
Yeah...here's one. It's been awhile since the last post 1-31.
https://g35driver.com/forums/engine-drivetrain-forced-induction/120735-poll-oil-consumption.html
Old Mar 12, 2007 | 12:03 AM
  #533
c35's Avatar
c35
Negative. Issues with both of our 03's.
Old Mar 12, 2007 | 09:26 AM
  #534
shdowflare's Avatar
I have an '03 with 35K miles and just started burning oil - 4 quarts in about 2,500 miles - after switching to synthetic.
  #535
shdowflare's Avatar
Yeah, I just read that somewhere. I may do it, depending on the cost.
Old Mar 22, 2007 | 12:26 PM
  #536
NorCalGRide's Avatar
Just another quick update. I’ve had mine at the dealer since Monday getting the short block replaced. Dealer is super nice and helpful, but I couldn’t get Infiniti to replace the entire motor, in fact, their customer support line is awful – the young broad assigned to my case was very rude and made it sound like she’s giving me a favor by approving the short block replacement.
Car should be ready today, so we’ll see how it goes… sucks having to go through the break-in process again.
My car is an ’06, 6MT, bought new few months ago. I noticed oil levels being low at 2,500 miles, did 4 consumption tests at the dealer, and at 6,500 Infiniti approved a new short block.
Old Mar 22, 2007 | 09:16 PM
  #537
BlueBOB's Avatar
Great. I noticed a funky noise coming from the motor as I shut it off, but figured it was just due to weather or just blew it off as nothing.
I bought new so I wouldn't have to worry about stupid ****. Ugh. The wonder of multiple vehicles.
Old Mar 24, 2007 | 01:11 AM
  #538
Thumbs down :(
Well, I’ve got my car back yesterday. Dealer drove it for about 20 miles after the new short block install to check for any issues. All checked out OK and I thought I was done dealing with this BS. Not that lucky…
This morning I hear a ticking noise on the way to work and on the way back from work a new “chirping” noise, which I can’t identify where it’s coming from – all happening only while the car is in motion. Next, the previously pleasant exhaust note has now been ruined by what I can best describe as a “fart” sound which happens upon acceleration at around 3K rpms… it’s as if some more air gets suddenly pushed thru around that engine speed for a quick second. Lastly, now when I turn on the AC, the fan belt (from what I can guess) is squealing as well.
Of course dealer’s service is out for the weekend, so I’ll be back to diagnose all these new noises next week. Just wonderful… I'm starting to dislike my new car now
Old Mar 24, 2007 | 05:31 PM
  #539
Texasscout's Avatar
Run it good this weekend. Work all the kinks out. So you'll be sure to have ALL the problems noticed when you take it back.
Old Mar 29, 2007 | 01:51 AM
  #540
ResIpsa's Avatar
ResIpsa Is Out
I started this thread in August and have been absolutely humbled and amazed at what it became. I never believed this problem would be so wide spread.
I am happy to say that I picked up my car from Infiniti of Chantilly with a new long block yesterday. I have to give my appreciation to the new service manager Steve Taden. He was able to adroitly handle a very angry customer.
I can’t begin to express my frustration with the previous service managers. Those guys would say anything to get me out of their hair.
I had previously been told three times that a new engine was approved and that it was on order. However, when I would come back they would look at me like they had no recollection of my problem.
Then they would make me undergo a bullsh*t oil consumption test until they re-diagnosed my problem and “approved a new engine”. When I would call for a time frame on the engine...you guessed it, no recollection of me or my problem.
And repeat...
Good luck to everyone who has this problem. I really appreciate all those who contributed to this thread.
ResIpsa out.
Attached Thumbnails Everyone: Check Your Oil!-ioc-long-block-jpg.jpg
You have already rated this thread Rating: Thread Rating: 5 votes, 4.80 average.
