G35 & G37, Coupes & Sedans
Switching to synth too early will void my warranty?
Old Sep 20, 2006 | 03:35 PM
bigd23's Avatar
Since when does it take 10-15k miles for rings to seat? In reality that's pretty much done happening at the factory when they run the engine a certain amount (at varying speeds) to test it. Modern engines come basically broken in and don't require the same break in period that old engines used to.
Like someone else said...if there were any issues it would be in bold letters in the owner's manual from Infiniti themselves. I put synthetic in the same 3.5 VQ motor in my Maxima at 1k miles...traded it with almost 50k on it...never had a problem and never had to put a drop of oil in the car between changes.
Old Sep 20, 2006 | 03:42 PM
2006_G_coupe's Avatar
I am not running syn oil till at least 25k.!! And when i do,im gonna use redline 5w30 syn.This is just my opinion though.!!
Old Sep 20, 2006 | 03:44 PM
fortified's Avatar
Most problems are magnified on forums. I have to believe the rings in most G35s are just fine with owners dumping in their favorite oil after break-in.
Old Sep 21, 2006 | 03:08 AM
MasterAv's Avatar
Thanks for all the responses guys.
Her reasoning was the same as that other guy's reasoning, oil consumption problems.
But I'll probably switch the next time I do an oil chance because I've already bought the oil and don't feel like paying Infiniti another $50 to get an oil change when I can do it myself =P. Hopefully I won't get any oil consumption problems...0_o
Old Sep 21, 2006 | 10:31 AM
fortified's Avatar
Nissan is typically cheaper than Infiniti for doing routine services, like oil changes, etc.
Old Sep 21, 2006 | 03:05 PM
ballisticus's Avatar
I would suspect that the majority of the oil "burning" issues are not from synthetic oil, but from wimpy break-in methods. If an engine does not experience full load and pressures for brief periods early on in life, it is not a good thing. I changed to M1 at 2200 miles and 74K now with no problems at all.
Old Sep 21, 2006 | 08:37 PM
HokieZ's Avatar
I believe syn oil is essentially regular oil, but with a drastically lower distribution of molecular weights. I don't see how it could possibly do any damage. Some have higher level of detergents, so they aren't necessarily recommended for higher mileage engines that haven't run them.
Dallsinghjr1
Sep 17, 2023 11:25 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
