G35 & G37, Coupes & Sedans
looking for larger oil filter for 05 coupe
Old Jun 27, 2007 | 09:43 PM
shdowflare's Avatar
Cool, I'll give the M1-105 one a shot. I wasn't able to track down the Castrol Syntec 0w30 Euro motor oil so I'll probably just go with Castrol Syntec 5w30 for this oil change.
I'll think ahead next time and have some Amsoil or the Syntec 0w30 on-hand before it's time to do the oil.
Old Oct 6, 2007 | 03:31 AM
badtziscool's Avatar
Bringing this thread back from the dead.
I want to use a larger filter myself, since I'm running on synthetic and thus have a bit longer change interval. My concern with using a filter not specified by the manual is that the operating pressures aren't within range of the larger filter.
I mean what happens if the normal operating oil pressure on the G is so high, that it's constantly above the bypass valve of the larger filter? If that's the case, then no filtering will occur since it's constantly being bypassed.
Old Oct 6, 2007 | 02:02 PM
Bigd2k6's Avatar
not sure if this helps but oil pressures are as follows
05 g35
idle - 100 kPa minimum
2k rpm - 290 kPa minimum
98 maxima (which was a larger filter and 3.0 VQ30DE engine)
idle - 69 kPa minimum
3k rpm - 435-551 kPa
05 qx56 (larger filter, 5.6L v-8 VK56DE engine)
idle - 98 kPa minimum
2k rpm - 298 kPa minimum
I think i'll give the qx56 filter a shot before the maxima
Old Oct 7, 2007 | 08:58 AM
daveblank's Avatar
The Maxima & QX56 use the same filter. 15208-9E000 is the part #.
Old Oct 7, 2007 | 02:20 PM
05 g35
That helps a lot!
Anyone else has input on this?
Old Nov 12, 2007 | 11:45 PM
kingrukus's Avatar
I am hearing a lot that the 15208-9E000 is the best filter to use with the VQ35 motor. Good thing I stocked up on them when I had a VQ30 in my last 2 maximas.
Old Nov 12, 2007 | 11:49 PM
BayAreaRefuGz's Avatar
i fly low
i use and have been using m1(EL): m-110
lemmy999
Jul 25, 2015 12:13 PM
ClwMike
Jul 23, 2015 12:55 PM
justgotg35
Jul 19, 2015 12:33 PM
