G35 & G37, Coupes & Sedans
How to correctly drive an MT.
Rating: Thread Rating: 3 votes, 5.00 average.
Old Jul 11, 2008 | 09:34 AM
  #196
dofu's Avatar
20 Year Member
Originally Posted by RBull
1. Yes, otherwise it will stall. No, slowing your speed below what idle speed is will stall the car.
Technically, there are the somewhat rare occasions when a new clutch can be good enough to hold the gear when you're practically stopped. It does take practice to get this to work, and I don't know how good or bad doing that is on your clutch.
Old Jul 11, 2008 | 08:31 PM
  #197
lush1's Avatar
Originally Posted by SteveZ
Your clutch is sticking before it fully engages? As in the pedal isn't coming all the way off the floor by itself? Happens a lot in hot weather maybe?
No, this isn't a purposeful design that prevents the clutch from coming all the way up. It's a problem.
Try http://www.my350z.com/forum/showthre...lutch+sticking or any number of threads searching on clutch + stick or sticking.
It's a problem due to usually either a) weak or defective slave cylinder, b) clutch fluid overheating due to the small amount of it and the routing of the line near the exhaust and cat, c) sometimes a problem with the clutch master cylinder. Heat is almost always a factor, whether from headers, normal exhaust pipes, weather (biggest one I can see).
When it's really bad, the clutch just sticks to the floor and is very slow to return at all. If nothing is actually wrong with the clutch components like the slave, M/C, etc. people often change out the fluid to a higher temp fluid like Motul not as affected by heat, and/or replace the stock line with stainless steel shielded with some heat-resistant material.
Your original question sounded more like a driving question which is why you didn't get the answer you are looking for. Nothing is designed to make the clutch stop partway up, this is a problem and yes, it will wear your clutch badly and cause premature replacement, and being a "wear item", isn't usually covered unless the M/C or something is defective.
HTH
Thanks SteveZ. You nailed it. That's the kind of answer I was looking for and you are right, I didn't express that clearly in my 1st post about this issue. It has only happened to me a couple of times in 47k miles of driving. Both times I was in a low gear, with pretty high revs (but nowhere near the red line) and the clutch pedal doesn't come all the way up. It happens fast and is over so quickly that it leaves me scratching my head and thinking "what the F just happened?" But it's not the kind of thing I want to try to reproduce because it's a real clutch burner. I didn't think it was designed into the car, but I have never had anything like this happen in any other MT car I have driven, and I've driven lots of them. It might be a heat issue, but it only happens once in a great while and otherwise the clutch works fine before and after the incident.
P.S. Thanks for the advise, pic and link.
Old Jul 29, 2008 | 04:50 PM
  #198
uhohitzmikeo's Avatar
does anyone get a lil shaking/vibration in first gear sometimes while releasing the clutch? it depends on how i release the clutch and my mood. it kind of vibrates/shakes/rattle the car a lil but it seems that only i notice and not my passengers. i dunno maybe im doing sumin wrong. i usually try go into first at about 1500. is everyone getting out of first a lil slower than all the other gears in order to be more smooth???
also read stuff about overcoming static friction. so if we are on a hill we have to overcome more static friction than on a flat surface. if we are on a hill do we need to go a tad bit higher in RPMS like around 2000 instead of 1500??
this car is a lil bit trickier in first gear than all the other cars i have driven so far....but not difficult.
do u guys always try to keep your clutch fluid to the max line? mines right now is between max and min.
Old Jul 29, 2008 | 05:21 PM
  #199
Texasscout's Avatar
Yes, it bothered me for a while, but like all noises I just ignored it.
Old Aug 17, 2008 | 03:04 AM
  #200
Infiniti_Mike's Avatar
I'm sorry if this question was already covered, but when going from a gear to neutral, it is necessary to hold the clutch in first without causing damage later on? For example, if I am cruising on the highway in 5th and want to put the car in neutral, do I have to first push in the clutch before going into neutral? Thanks
Old Aug 17, 2008 | 08:09 AM
  #201
Texasscout's Avatar
Not really.
Old Sep 17, 2008 | 10:42 PM
  #202
BostonG6spd's Avatar
If you are just cruising, what RPM is the best to shift gears? (for saving gas, and good for the engine/clutch)
I usually shift at 2100 RPM's if i am just cruising.
Old Oct 5, 2008 | 07:21 PM
  #203
ballinitup56's Avatar
question guys......when downshifting, example from 4th to 3rd, do you need to double clutch? or is it ok to clutch and rev match while the clutch is still down then release? ive heard that this will mess up your clutch but it was an un reliable source...thought i would ask the pros..thanks!!
Old Oct 5, 2008 | 07:55 PM
  #204
AGThing1227's Avatar
Don't consider me reliable. But press in the clutch, blip the throttle, downshift and your good to go. No need to double clutch in cars today. Although I have heard that it is always good to double clutch going from 2nd to 1st. How true is that? I have no idea.
Old Oct 5, 2008 | 08:09 PM
  #205
cool man thanks! i just needed to hear it from someone who has a g and has been driving for a while! just making sure that it wont mess up my clutch in the long run.....plus it saves a lot of time over double clutching.
Old Oct 5, 2008 | 08:16 PM
  #206
Ha, don't count me than! I never had a G, I was going to but than got an E46 M3. Being 17 I have very very little experience with a car clutch. But a manual is a manual. You use the same general concept. You have a G35, not a Mack truck. So don't sweat it. I was asking for help to drive a manual a few months back and now I have the general concept down for a car. Good luck man!
Old Oct 5, 2008 | 10:03 PM
  #207
dammmmnnn 17 and u got an m3??? nice work man thats the car i wanted to get but its way to expensive.....my next car for sure! enjoy it and thanks for the tips!
Old Oct 6, 2008 | 10:33 AM
  #208
ok what does "blip" the throttle mean?
Old Oct 6, 2008 | 11:09 AM
  #209
Texasscout's Avatar
if you are downshifting, you "blip" the throttle (give it a quick punch) to "rev-match) the engine revs to the speed of the gear selected. It makes less wear on the transmission syncros (and clutch) by having the gear selected and engine speed matched.
Originally Posted by Everything.com
REV MATCHING is a driving technique for shifting a manual transmission smoothly. One simply memorizes approximately how many RPMs different the various gears are from one another at the same speed, and then matches the engine's revs with the gear they are shifting in to. When upshifting, you just let the revs drop and slip into gear. When downshifting, you tap the throttle (or stomp on it depending on how long it takes to rev up.) This is often referred to as 'blipping' it. This works easily primarily because of the syncromesh gears in your transmission; if your transmission does not have them, this is very, very difficult to do without grinding. Even so, it takes the right touch.
For example, in one car the gears might all be approximately 1,000 RPM apart at the same speed. When downshifting from third to second, for example, you would apply accelerator pressure to raise the engine RPMs by 1,000 (say, from 3,000 to 4,000) and make your shift. You can then use engine braking to reduce your speed.
This practice results in reduced brake wear, less of a lurch when shifting from a higher gear to a lower one, less clutch slippage when shifting from a lower gear to a higher one, and a smoother shift without having to slip the clutch so much.
In auto racing, one often uses the more advanced form of this activity, heel-toeing (Alternately heel-toe braking or heel-toe downshifting) in which one's heel is on the brake pedal, decelerating, while the toe is on the gas pedal, accelerating. This allows the use of both the brakes and the engine to perform braking.
Old Oct 7, 2008 | 10:42 PM
  #210
mreh's Avatar
So just an update, I've had my 6MT coupe for 2 months now and am pretty much set with it... this was my first manual car I just made sure to take it easy and not wear the clutch... now I'm fine with it everywhere, now I drive the thing into manhatten on occasion ( )... though gotta admit I still get a little shook if I'm in traffic stopped a big hill
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
