G35 & G37, Coupes & Sedans
How to correctly drive an MT.
Rating: Thread Rating: 3 votes, 5.00 average.
Old Oct 19, 2007 | 08:59 PM
  #136
DefJux921's Avatar
Originally Posted by psteng19
Good post but a few things I disagree with.
You missed a step in double clutching.
1. clutch in
2. shift to neutral
3. clutch out
4. while clutch is still out, shifter still in neutral, blip throttle/rev match
5. clutch in
6. shift to desired gear
7. clutch out & gas
Double clutching does still have its purposes.
1. It saves synchros.
2. It lets you downshift to first, which is when I double clutch (I also double clutch when dropping 2 gears out of habit)
Another thing about downshifting into first.
Cars with low torque, e.g. 4 cylinder cars, will lug in 2nd gear going at speeds lower than 5-10 mph, especially up an incline.
Help your engine out, downshift to first. Lugging is extremely bad for the engine.
+1 - on my last car (civic with gsr motor and trans) i had to replace 3rd gear and all the syncro's.... the guy at stick's only told me i could save my syncro's by double clutching.
also double clutching incorporates rev-matching - rev-matching alone will produce smooth shift but it won't save the syncro's (the layshaft doesn't come up to speed)
i'll have to try shifting to first while moving but im pretty sure i've done it while going around 10mph (with double clutching of course) - i don't do it often but when i need it wow it gives u mad power... love that first gear
Old Nov 5, 2007 | 04:03 PM
  #137
pCHILLEN's Avatar
going to stop signs, do you guys down shift the 1st? or leave it in 2nd? I found it hard to downshift the 1st sometimes.
Old Nov 6, 2007 | 09:59 AM
  #138
chilibowl's Avatar
did you read the word document I posted in my 1st post? It answers your question
Old Nov 6, 2007 | 12:06 PM
  #139
pCHILLEN's Avatar
i drove around a bit and figured it out. thanks chilibowl, great writeup!
Old Nov 6, 2007 | 12:09 PM
  #140
MIA BlazinVQ's Avatar
brb getting cut
ok i've been wondering for a while now... do you guys ever let the clutch all the way out when you're in reverse?
I've never had the courage to let it all the way out while backing out of my driveway, but I've just wondered what would happen if I let
it all the way out.
Old Nov 6, 2007 | 12:10 PM
  #141
Klubbheads's Avatar
not when u are just going 10 ft, if u are gonna do revers 180 then ya.
Old Nov 7, 2007 | 09:07 AM
  #142
chilibowl's Avatar
it all the way out.
Like Klubbheads stated, if ur just backing up outta ur driveway, theres no need to. If you need to back up really fast and for a bigger length, you may release the clutch just as you would forward gears, and all control will be on the gas pedal. Be easy tho, reverse is a very short gear.
Old Nov 20, 2007 | 07:16 AM
  #143
alderran's Avatar
Is it just me or is this car extraordinarily difficult to downshift into 2nd gear when the transmission is cold?
Unfortunately for me my commute home is a slow roll but never really stops. I'll be going 30 then down to 5 then back up to 30. This goes on for 4 or 5 miles till I break free of the city. The car does not want to go into 2nd until I am nearly stopped. I'm going way too slow to be in 3rd, but it won't go into 2nd.
Is this normal or a sign that my tranny is going? I don't remember it being like this last winter. Although to be fair, I was driving with my wife and had to cut across town and pick her up, so by the time I got to the slow highway roll the transmission may have been warmed up.
I love the way this car looks and handles but the transmission and the pinging motor isn't leaving me with a warm fuzzy feeling for Infiniti
Old Dec 5, 2007 | 03:57 PM
  #144
chilibowl's Avatar
Start your car 2 minutes before leaving to work?....
Its definitely your car tho, I say you get it checked out before your warranty expires
Old Dec 11, 2007 | 08:14 AM
  #145
alderran's Avatar
Warming up the engine won't warm up the transmission. Only driving will do that.
Old Dec 11, 2007 | 07:33 PM
  #146
Texasscout's Avatar
It will if it's an automatic.
Old Dec 12, 2007 | 09:26 AM
  #147
chilibowl's Avatar
So much for a 6MT thread
Old Dec 12, 2007 | 10:16 AM
  #148
Texasscout's Avatar
Sorry, I couldn't help myself.... (sulks off into corner of room)
Old Dec 18, 2007 | 07:53 AM
  #149
alderran's Avatar
Coming from the home state of that nightmare Bush I'd be keeping your head real low. Even Hillary would be better than him
Old Dec 18, 2007 | 08:11 AM
  #150
chilibowl's Avatar
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
