G35 & G37, Coupes & Sedans
How to correctly drive an MT.
Old Jul 22, 2011 | 09:26 AM
  #406
visualfxpro's Avatar
Originally Posted by saywat?
^quick shifting like when ur trying to go fast? my car shifts even better and faster at higher rpms
In my Celica I used to shift in less than a second and didn't even use the clutch pedal. I miss that. Now I know the clutch pedel-less shifting is not going to happen in the G, but I was also hoping to engage the next gear much faster without jerking the car(UNLESS your RPMs are PERFECT). Funny thing is the Celica may have been just as bad, it just maybe lacked enough power to make you FEEL how far off your RPMs were.
Old Aug 19, 2011 | 11:24 AM
  #407
Aznteazer's Avatar
This is a really good post for ppl who never rev match their gears. Ive been driving correctly from day 1 but ive had my transmission replaced once already and am currently hearing another noise that im going in for a checkup tmrw. Bottom line, infiniti transmission blows!
Old Aug 20, 2011 | 12:07 AM
  #408
jttizzle1995's Avatar
bump
Old Aug 20, 2011 | 01:14 AM
  #409
saywat?'s Avatar
U sure u shifting correctly?
Old Aug 20, 2011 | 09:05 AM
  #410
VincenzG35's Avatar
+1 the G35 has one of the strongest trannys
Old Aug 22, 2011 | 03:32 AM
  #411
jibberjabbers's Avatar
It's certainly not the smoothest tyranny's out there. The engagement point is also way too high.
Old Aug 22, 2011 | 07:16 AM
  #412
NFSP G35's Avatar
? = 2B || !2B
^One of those things depends on year, and the other depends on the clutch.
Old Aug 22, 2011 | 08:11 PM
  #413
Drummachine's Avatar
Excellent POST
Old Aug 22, 2011 | 08:45 PM
  #414
John_C's Avatar
Wow ... I had no idea that a thread about changing gear would cause so much discussion, and as for Chili's assertion that ...
Originally Posted by chilibowl
"double-clutching" .. is simply f*cking stupid. Whoever is doing this, is seriously wasting their time ...
I'd say that there's a time and a place for everything ...
Serious question though. What are the options for levelling out the pedals for easier heel and toe changes?
Old Sep 2, 2011 | 12:54 AM
  #415
AARONHL's Avatar
I've been STOMPING hard on my clutch pedal and it actually improves shifting smoothness.
Old Sep 4, 2011 | 11:02 AM
  #416
chalyse's Avatar
Old post but good write up for a newbie...thanks...
Old Sep 18, 2011 | 08:03 PM
  #417
dmarz45's Avatar
I've been reading alot about rev matching when down shifting. Tell me if this is right.
I'm in 4th at 2k rpms and I want to downshift into 3rd. I would push in the clutch and shift into third. Now with the clutch still held in, I would blip the throttle to 3.5k, then let off the clutch and give it a little gas.
Is that the correct way to do it? I thought it was bad to hit the gas when the clutch is engaged??
Old Sep 18, 2011 | 08:21 PM
  #418
John_C's Avatar
Originally Posted by dmarz45
... Tell me if this is right.
Yup, pretty much.
Give it a bit of a blip as you are starting to let off the clutch and off you go.
You shouldn't have too many dramas changing down at that sort of speed, but I'd suggest getting plenty of practice, and start building up the speeds slowly before you try down shifting at 5k rpm.
The bad part about hitting the gas with the clutch in is that there is a danger of over-revving an engine, but as these cars have got rev limiters there is no drama ... other than looking and sounding like a moron when you completely screw up a gear change ... that can be damaging to the ego ...
HTH
Old Sep 18, 2011 | 08:51 PM
  #419
dmarz45's Avatar
Originally Posted by John_C
Yup, pretty much.
HTH
thanks for the info. I'm just a casual driver so Im probably not going to be doing alot of downshifting at 5k rpms, but I do want to do whatever is best for my car.
Just to clarify, so it is okay to blip the gas while the clutch is held in? A "blip" would just be considered a very short, quick tap right?
Old Sep 18, 2011 | 08:54 PM
  #420
AARONHL's Avatar
Only when partly engaged. You do really want to be on the gas and clutch at the same time, you have to simultaneously hit the gas and release the clutch pedal.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
