G35 & G37, Coupes & Sedans
How to correctly drive an MT.
Rating: Thread Rating: 3 votes, 5.00 average.
Old Nov 5, 2012 | 03:57 AM
  #556
Hemsky's Avatar
i want to order a dual mass 31 pound oem fly wheel were is my best bet of finding on dealership or online?
Old Nov 5, 2012 | 09:15 AM
  #557
Texasscout's Avatar
Originally Posted by Hemsky
were could i purchase a RJMbracket and install it, also i think my clutch is burnt...it doesn't jerk my car forward when i engage the clutch after accelerating in a gear(like my old one)at all when i engage clutch it feels like its just barely getting the gear into neutral, sometimes slipping barely opening the gear box. sometimes i have hard time getting the shifter into gear i can feel the gearbox grinding on the shifter barely wanting to open... and i know how to drive mt its not my driving the clutch in this car just feels like a toy, maybe i am not use to the 13 pound lightweight flywheel...vs my old 31 pounds oem...but...i don't really want to get use to it if this is how it performs... i like my old 31 pound oem flywheel think my best bet is to replace with a 31 pound oem flywheel and RJM bracket... i even smell burned clutch smell omitting from under my car to inside the interior... i don't mind spending some coin to replace everything if someone could just tell em exactly what i need cuz i went o a shop and they said i don't need a new fly wheel they just "resurface" it and then install a new clutch and use my same flywheel... how ever if this is the case i do need a new one... cuz this 13 pound bs isn't cutting it now if i do so do i need a new clutch as wheel... what is my best bet to take to my local infiniti dealership or a local specialist here in the city... or order a clutch kit and get my family mechanic to do it...?!?!?!???? . your replys are grately appreciated!
OMGIDON'TTHINKICAN READALLTHISJUMBLEDTOGETHER!
I would suggest the Jim Wolf Technology clutch PACKAGE. It includes a light weight flywheel, clutch disc, Pressure plate, throw out bearing, pivot bearing, Stainless Steel clutch slave line and other goodies. You can buy it for + or - $800.00 and it will cost you $4-500 for the install. MUCH better clutch for MUCH less money than the STealership. Two things, it is a lot stronger clutch (450 hp+) and the pedal feel shows it. The lightened flywheel will give off a rattle at idle, this is normal. IF you can't stand the rattle, you will need the factory dual mass flywheel.
www.importpartspro.com send an email to Kyle.
Old Nov 5, 2012 | 09:21 AM
  #558
Texasscout's Avatar
ok thanks you but this looks very complicated i could see myself ruining my clutch or installing it wrong and my clutch not even working... is this a simple instal? and this give make my clutch feel heavier>
NO
If you are not a regular mechanic, don't try it. I got mine put in for $400 about 2 years ago.
You have to remove the exhaust, crossmember and make sure you get the correct clutch pilot tool to align it alll up, not something you want to do on jack stands.
Old Nov 5, 2012 | 11:01 AM
  #559
SAMzG35's Avatar
G35
Chatter noise is very annoying & I hate it. I used Osiris to up my idle to 850 it's a little better but still there.
I think he was askin about the RJM bracket install, not clutch replacement.
Old Dec 6, 2012 | 11:59 AM
  #560
SPerkins721's Avatar
Great Write-up. Too many people around here in their Z fly around downshifting without ANY rev match... hilarious.
Old Jan 17, 2013 | 01:38 AM
  #561
drummr8's Avatar
good writeup of common sense that many people don't have
Old Apr 8, 2013 | 01:15 PM
  #562
evil-G-nius's Avatar
I read pretty much all of this at one sitting so I may have forgotten...but I thought some of the G's (I know the Z did) came with a Rev feature that automatically matches your revs for smooth shifting. Is this not true or is it just not as accurate as trying to do it yourself? I am not new to manual trans but I was just curious. I am looking to get a 6MT at some point and I just wanted to know if my car would end up with it. I think 05 -07 had that rev match tech...am I right?
Old Apr 8, 2013 | 01:20 PM
  #563
Texasscout's Avatar
Yes, some of the later MTs had the "Rev Match". It matched the RPM on a down shift to make it smoother. I don't remembe the year.
Old Apr 8, 2013 | 01:22 PM
  #564
jsolo's Avatar
Only the 370Z's come with this. Not available in any MY G37's.
Old Apr 8, 2013 | 02:46 PM
  #565
^^^Completely false. '05-'07 G35's had it. I don't know if all 6MT models did but I know that some came with it. I can't speak for the G37 though
Old Apr 8, 2013 | 02:48 PM
  #566
TORETTO's Avatar
^ dafuq?
Old Apr 8, 2013 | 02:52 PM
  #567
TORETTO's Avatar
my 05 6mt does not rev up the rpm for me on a downshift. I still have to manually do it.
Old Apr 8, 2013 | 02:53 PM
  #568
jsolo's Avatar
We're talking about real manual trans cars, you know, clutch pedal, double H gear shifter, etc.. Not sure if the 5AT had downshift rev matching or not, but that's not what's in question.
Old Apr 8, 2013 | 03:07 PM
  #569
Apparently some 05's have it. I am guessing since not everyone has it it was an option.
Old Apr 8, 2013 | 04:03 PM
  #570
izzueeek's Avatar
LoL
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
