G35 & G37, Coupes & Sedans
How to correctly drive an MT.
Rating: Thread Rating: 3 votes, 5.00 average.
Old Mar 28, 2012 | 09:36 PM
  #496
AARONHL's Avatar
^And those people that keep their foot off the pedal are the ones shoving the shifter into 1st as quickly as they can before the car behind them beeps! Their synchros must love them
Old Mar 28, 2012 | 09:53 PM
  #497
TORETTO's Avatar
Well I keep one foot on the brake when stopped. I don't leave all 3 untouched if that's what OP was getting at.
Old Mar 28, 2012 | 10:22 PM
  #498
AARONHL's Avatar
Gotchaaaaaa
Old Apr 15, 2012 | 04:10 PM
  #499
garfield's Avatar
this tips are really helpful. I'm hoping to get more into MT
Old Apr 15, 2012 | 09:16 PM
  #500
MidKnight's Avatar
Good write!
Old Jun 22, 2012 | 08:34 AM
  #501
Michaelh90's Avatar
Great Info in this Thread!! Thanks got to finish reading all the posts.
Old Jun 22, 2012 | 08:57 AM
  #502
faiz23's Avatar
Now go out there and kill your clutch...
Old Jun 26, 2012 | 05:17 PM
  #503
btran35's Avatar
at a complete stop i normally let off the clutch without gassing to start the car rolling. Is that ok?
and sometimes when shifting up i would do the same for instance: from 2nd gear i would clutch in and put it into 3rd then release the clutch slowly without gassing. Once 3rd is fully engaged with the clutch fully off then I would start pressing on the gas. Is that ok as well?
Old Jun 26, 2012 | 05:44 PM
  #504
Texasscout's Avatar
Sounds like you're doing it correctly to me.
Old Jun 26, 2012 | 05:48 PM
  #505
saywat?'s Avatar
^i dont do this but i dont see how he could make the car roll in second without the car dying or riding the clutch and doing some heavy revving
Old Jun 26, 2012 | 06:07 PM
  #506
jsolo's Avatar
While you can do this, and it works, bear in mind you'll be a candidate for PCR - premature clutch replacement
The idea is to MINIMIZE the amount of time the clutch is slipping. This is when the wear occurs. Get it engaged as quickly and smoothly as possible. Your feet should be synchronized.
Old Jun 27, 2012 | 01:43 PM
  #507
dofu's Avatar
20 Year Member
Technically, if can grasp the concept that the clutch is what connects the motor to the drivetrain, then logic should tell you otherwise. If the car is rolling from any kind of power from the motor, that would mean the clutch is already engaged, as the drivetrain would have to be connected to the engine to move the car.
Stepping on the gas after the car is moving from the power it makes at idle would then be assuring that the clutch is properly engaged before you give it power. Now if you give it gas before you've lifted your foot of the clutch, before the clutch fully engages, it should make sense that you are making it harder for the clutch to catch properly, therefore making your clutch catch harder or slip more than necessary.
Old Jun 27, 2012 | 02:12 PM
  #508
jsolo's Avatar
Dofu, reread what was posted in post # 503 - the car is completely stopped. If you let off the clutch as quickly as you would while feeding throttle WITHOUT giving any throttle, the engine will stall. So if you give no additional throttle to get moving, the clutch release will have to be much slower, resulting in more clutch wear
Old Jun 27, 2012 | 02:27 PM
  #509
dofu's Avatar
20 Year Member
True, the faster you let off the clutch, the better, but that really only works when the clutch and flywheel are spinning.
You don't have to release the clutch as slow as you make it seem, you just have to know the engagement point where the clutch actually catches.
Excessive wear happens when the clutch and flywheel are at different speeds, the greater the difference, the worse the wear. So think about what happens when you step on the gas before you engage the clutch.
Old Jun 27, 2012 | 02:29 PM
  #510
saywat?'s Avatar
from experience with this car all i know is release clutch faster need more gas. if releasing clutch slowly need less gas
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
