G35 & G37, Coupes & Sedans
Instrument lights go out when I turn on headlights
Old Jan 23, 2008 | 08:10 PM
bradster's Avatar
So when I turn on my headlights, the dash (instrument cluster) lights go out. Also, the headlights won't turn on unless I turn on the foglights. If I turn off the headlights, the instrument lights go back on. I pulled out the radio and the issue remains the same. Could it be the BCM? Anyone seen this behavior? TIA.
Old Jan 23, 2008 | 08:58 PM
dave's Avatar
Are you sure the dimmer hasn't been turned down all the way? It's a wheel down by the VDC and trunk switch.
Old Jan 23, 2008 | 10:37 PM
OnE BaD G35's Avatar
^^^Lol yeah i would check that
Old Jan 23, 2008 | 10:40 PM
BlueDevilBAMF's Avatar
LOL yeah sounds like the dimmer is turned down to me --> but that doesn't explain the headlights only going on if the fog lights are on?
Old Jan 24, 2008 | 12:50 PM
bradster's Avatar
OK I feel retarded, someone did mess w/ my dimmer. Thanks much, Dave. However, I still have the headlights/foglights issue. Can't seem to figure that one out.
Old Jan 24, 2008 | 12:57 PM
DRIP's Avatar
A bit of a wild guess, but check your fuses. In older cars, sometimes if a fuse would blow, the current would sometimes bleed over and use a fuse next to it, causing odd things such as this. I haven't seen this in a long time, but its an easy one to check.
Old Jan 24, 2008 | 02:01 PM
bradster's Avatar
Thanks, but that was the first thing I checked.
Old Jan 26, 2008 | 08:53 AM
dave's Avatar
That sounds like either the light switch or the BCM has gone bad.
Jusseth
Sep 13, 2020 12:25 PM
bTanz
Oct 15, 2015 02:31 PM
wonderizm
Sep 24, 2015 03:09 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
attarday
Jul 15, 2015 04:03 PM
