G35 & G37, Coupes & Sedans
Stealer Recommends BG-1 Fuel Inj. Srvc... need?
Old Mar 25, 2009 | 07:47 PM
UR2EZ's Avatar
my local stealer keeps harping me about getting this BG-1 fuel injector cleaning service they offer for $130.
once in a while i use a bottle of Techron in the gas tank...
does anyone know what they do to clean the fuel injectors??
Old Mar 25, 2009 | 09:12 PM
sleev-les's Avatar
I used to get a kit that had fuel injector cleaner, a cleaner that you hook to a vacuum line that goes and cleans carbon deposits off cylinder heads and a spray cleaner to clean out the throttle body. You can do it yourself if you really wanted to do that. Dealer is insane and it also won't do much if your car has low miles.
Old Mar 25, 2009 | 09:24 PM
Darkstar752's Avatar
You can probably get a local shop to do more for cheaper.
Old Mar 25, 2009 | 09:27 PM
pinkii's Avatar
be careful. I was in the dealership and this dude was getting his M45 serviced... he got a fuel injection service at a "shop" and it cost him 950 in repairs.
Old Mar 25, 2009 | 10:29 PM
UR2EZ's Avatar
yeah i've been reading more online, it seems modern cars using regular gasoline here in the US shouldn't need this service until maybe 150,000 miles. i was also reading about seafoam, but i couldn't bring myself to put anything in my oil and intake manifold.
Old Mar 26, 2009 | 10:06 AM
LightsOut's Avatar
SIETESG
sea foam works great, but i dont think our cars need fuel cleaning until 100k miles range
Old Mar 26, 2009 | 11:30 AM
yourdoinitwrong's Avatar
The BG-1 system is a little different than just a tank additive. The $130 service is probably the 3 can deal (there is a 7 can) which consists of a fuel tank additive, intake cleaner, and a fuel injector and fuel rail cleaner. The intake and fuel injector cleaners are put through under pressure so it does a better job than just an additive that goes in the tank. I work at a dealer and just went back and asked a couple of our techs what they thought of it and they both agreed it works very well. They said if you have a higher mileage car with deposits or buildup the BG-1 system does a better job than Techron, but if you don't have the buildup then you won't see much difference. It wouldn't hurt to do it but the benefit depends on how much junk is in the fuel system.
Old Mar 26, 2009 | 11:40 AM
Jeff92se's Avatar
Red Card Crew
Question is how did they determined you needed it? They look at the injector duty cycles? Scope the combustion chambers though the plug hole?
Old Mar 26, 2009 | 11:50 AM
PAIXAO's Avatar
I have it done regularly on both of my cars every 30k.
Old Mar 26, 2009 | 05:18 PM
mrdwaters's Avatar
From page 9-4 of my owners manual:
Aftermarket fuel additives
INFINITI does not recommend the use of any
aftermarket fuel additives (i.e. fuel injector
cleaner, octane booster, intake valve deposit
removers, etc.) which are sold commercially.
Many of these additives intended for gum,
varnish or deposit removal may contain active
solvent or similar ingredients that can be harmful
to the fuel system and engine.
I think those "services" are sources of HUGE dealer profit. my 2 ¢
Old Mar 26, 2009 | 05:55 PM
FenixL1P's Avatar
i've filled up on 91 octane chevron and shell ever since i got the car so i'm pretty sure the injectors and lines should be clean. the price is pretty steep.
Old Mar 27, 2009 | 10:01 AM
LightsOut's Avatar
SIETESG
same here
Old Mar 27, 2009 | 11:15 AM
ttrank's Avatar
Grocery getter
I run a can of BG K44 every 20k miles. The local dealer by my work does the same thing for their "basic" fuel system clean.
Dallsinghjr1
Sep 17, 2023 11:25 AM
f22raptor
Mar 18, 2016 08:50 AM
dseet
Oct 11, 2015 12:40 AM
RWDguy4238
Sep 30, 2015 12:13 AM
Hogbone
Sep 28, 2015 06:44 PM
