G35 & G37, Coupes & Sedans
Discolored headlights....
Old Mar 23, 2010 | 12:58 PM
DamnYankee's Avatar
We just picked up a 2004 G35 coupe and the headlights aren't in great shape.
I will definitely use the search feature but I'm strapped for time and just wanted to get the question out there.
I assume others have had the problem...is the best solution picking up some replacements from eBay, from a salvage yard, or is there a way to restore them?
The discoloration appears to be on the inside...not sure how easy the lights come apart.
Thank you in advance!
Old Mar 23, 2010 | 01:11 PM
Nick05LS's Avatar
If it's on the outside, then you can use one of the many headlamp restoration kits out on the market. Most attach to a hand-help drill and are relatively easy to use. Or if you already have some sort of polisher for your car, then you can try that with a light polishing compound.
http://paintcarendetailing.com/gal_diamondite.html
If it's on the inside, then you'll have to open the headlamps. This requires you to heat them up (most people use either a heat gun or oven) to melt the rubber seal and then pull the lens away from the housing. I doubt the discoloration is really on the inside, unless the headlamps have been opened before.
Old Mar 23, 2010 | 01:21 PM
erklep's Avatar
+1
id say 99% percent of the time it is on the outside. most people assume it is on the inside b/c it doesnt simply wipe off from the outside. it does take a little elbow grease and a drill or buffer but they can be restored to as clear as they were from the factory with a little work.
Old Mar 23, 2010 | 01:23 PM
DamnYankee's Avatar
Yeah...I can't feel anything on the outside, but I don't know how it would get on the inside. I'll pick up one of the kits this evening and try it.
Thanks guys.
Hotdawwgman's Avatar
sweet... good to know!
Old Mar 23, 2010 | 01:25 PM
gary c's Avatar
Welcome to DRIVER Yank, if the discoloration is on the outside you can buy plastic cleaner/polish and remove it. If it's on the inside save your $ and buy a set of '06 G35 coupe projector headlights, they're 100% better than the OE '04s. I found mine on eBay, new in the box for $435 and they're plug & play.
Gary
Old Mar 23, 2010 | 01:35 PM
DamnYankee's Avatar
Great info - thanks for the tip and thanks for the welcome.
Old Mar 23, 2010 | 07:20 PM
illusionzrcer's Avatar
i used a product called glassylite. got it off amazon for around twenty bucks i think but the stuff is awesome. it only comes with enough stuff for one pair of headlights though but made my headlights look like new.
http://www.glassylite.net/
Old Mar 23, 2010 | 07:22 PM
WhosRich's Avatar
3M headlight restoration kit.
Old Mar 23, 2010 | 08:37 PM
Osa713's Avatar
its on the outside from oxidation. I got mine sanded down and polished at a body shop. They look brand new now
Old Mar 23, 2010 | 08:49 PM
xxgijojoxx's Avatar
+1 on 3M restoration kit
Old Mar 23, 2010 | 08:50 PM
Neu Era's Avatar
use the search button. or just use maguires plastic X polish. it's got our cars on the front of the bottle!!!DOMO
OU812G350
Feb 21, 2007 03:59 PM
v35skyl1ne
Oct 2, 2006 04:25 PM
ryanwiggum
Feb 11, 2006 10:24 PM
speedeezx
Intake & Exhaust
Feb 5, 2005 09:07 PM
