SES light on after Z-Tube and K & N install
Hey Guys,
Need help please, I installed a Z-tube and K & N back in January since then my SES light has come on twice showing 02 oxygen sensor. I never had the light come on before this mod. It's 04 G coupe with only 40,000 miles on it and never have had any problems. The exhaust seems to be a little louder at 3,000 rpm and seems to run normal but, it also seems like my gas mileage has gotten worse as well. The battery was not disconnected during the install, does it matter? Getting an Apexi WS2 installed next week as well, will the new exhaust help?
Thanks in advance,
KT
Thanks in advance,
KT
Try putting the ecu into "learn mode" and see if that works. Type "ecu reset" in the search box and read up on how to do it and other resets. Btw,what code was thrown for the sensor?
Damn,beaten to it by post #2,gotta be quicker on the trigger. You shouldn't have to do a TB reset unless it was unplugged. Also,since it's a K&N filter that needs to be oiled make sure the oil is dry before installing or it can foul the MAF sensor. I bought a 2nd K&N so I can swap in a ready filter at the same time as taking off the dirty one.
Thanks for the replies, I don't remember the code #. All hoses ans clamps are tight. I have no idea how to do any resets on this car. Will disconnecting the battery do anything ?
Thanks,
KT
Thanks,
KT
Don't buy the K&Ns, those things suck in **** like no tomorrow. Buy an amsoil or Green filter. They trap a lot more debris than the K&N.
most likely its due to you not disconnecting your battery before the install and you jsut messed with the wiring..
you should try resetting your ECU.. that should get rid of it
a tutorial on how to do it should be on this website.
^^^ just disconnecting the battery wont do anything.
you have to do the ECU reset where you turn off the car and turn it to on and then pump the accelerator 5 times and etc etc..
You didn't touch your throttle body butterfly did you? What are you idling at? I'd do a relearn. Sounds like the same problems I had after doing a throttle body cleaning incorrectly.
here you go
<u>Basic ECU Reset</u>
Operations Procedures:
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” (NOT start) and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone. If the CEL light continues to remain ON, repeat the above steps. Remember, timing is EXTREMELY critical to resetting the ECU. You may even need someone's help to do this correctly.
Note: The following reset procedures are directly from the 2004 G35 Sedan Service Manual.
<u>Accelerator Pedal Released Position Learning</u>
Description:
Accelerator Pedal Released Position Learning is an operation to learn the fully released position of the accelerator pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time harness connector of accelerator pedal position sensor or ECM is disconnected.
Operation Procedure:
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch ON and wait at least 2 seconds.
3. Turn ignition switch OFF and wait at least 10 seconds.
4. Turn ignition switch ON and wait at least 2 seconds.
5. Turn ignition switch OFF and wait at least 10 seconds.
<u>Throttle Valve Closed Position Learning</u>
Description:
Throttle Valve Closed Position Learning is an operation to learn the fully closed position of the throttle valve by monitoring the throttle position sensor output signal. It must be performed each time harness connector of electric throttle control actuator or ECM is disconnected.
2. Turn ignition switch ON.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
<u>Idle Air Volume Learning</u>
Description:
Idle Air Volume Learning is an operation to learn the idle air volume that keeps each engine within the specific range. It must be performed each time electric throttle control actuator or ECM is replaced, or if idle speed or ignition timing is out of specification.
Preparation:
Before performing Idle Air Volume Learning, make sure that all of the following conditions are satisfied. Learning will be cancelled if any of the following conditions are missed for even a moment.
- Battery voltage: More than 12.9V (At idle)
- Engine coolant temperature: 70 - 100 Degrees C (158 – 212 Degrees F)
- PNP switch: ON (Park/Neutral Position Safety Switch - AT only, MT fully depress clutch)
- Electric load switch: OFF (Air conditioner, rear window defogger, headlamps. Note: on vehicles equipped with daytime light systems, if the parking brake is applied before the engine is started, the headlamps will not be illuminated.)
- Steering wheel: Neutral (Straight-ahead position)
- Vehicle speed: Stopped
- Transmission: Warmed-up (For A/T models, drive vehicle for 10 minutes.)
1. Perform "Accelerator Pedal Released Position Learning"
2. Perform "Throttle Valve Closed Position Learning"
3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic PREPARATION (previously mentioned) are in good order.
6. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds:
7a. Fully depress the accelerator pedal.
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications:
Idle speed A/T: 650rpm, + or - 50 rpm (in P or N position)
Idle speed M/T: 650rpm, + or - 50 rpm (in N position)
Ignition timing A/T: 15 Degrees BTDC, + or – 5 Degrees BTDC (in P or N position)
Ignition timing M/T: 15 Degrees BTDC, + or – 5 Degrees BTDC (in N position)
13. If idle speed and ignition timing are not within the specification, Idle Air Volume Learning will not be carried out successfully. If idle speed and ignition timing are within the specification and Idle Air Volume Learning cannot be performed successfully, find the cause of the incident by referring to the following Diagnostic Procedure:
1. Check that throttle valve is fully closed.
2. Check PCV valve operation.
3. Check that downstream of throttle valve is free from air leakage.
4. When the above three items check out OK, engine component parts and their installation condition are questionable.
5. If any of the following conditions occur after the engine has started, eliminate the cause of the incident and perform Idle Air Volume Learning all over again:
- Engine stalls.
- Erroneous idle.
Description:
Description:
Description:
Preparation:
- Engine stalls.
- Erroneous idle.
Hasanbaloch
Feb 29, 2024 08:45 PM
Wayne9011
Jul 27, 2015 11:25 AM
