G35 & G37, Coupes & Sedans
Non Fouler!!
Old Sep 30, 2010 | 02:44 PM
dcryan90's Avatar
Non Fouler!!
ok so i posted a while back on how a screwed up one of my cats and i was going to switch to berk hfc to fix the SES but i have to go buy some new tires so that will have to hold for a while... so i tried to make a non fouler and it worked but now if i sit there and rev the SES light willl flicker is that normal for a non fouler? and would this prevent me from passsin emisions? if needed i could post a video
Old Oct 5, 2010 | 06:08 PM
Hammerhead i-Eagle Thrust's Avatar
in my experience ses lights(or CELs) tend to stay on once the secondary o2 sensor trips them until you reset them. flickering usually means a misfire, why dont you check for codes?
Old Oct 5, 2010 | 06:33 PM
dcryan90's Avatar
yea thats just it there wasnt any code it just was flickering but now since i have had the non fouler on a while it hasnt done it again so i guess problem fixed
Old Oct 5, 2010 | 07:01 PM
guess so
Old Oct 6, 2010 | 01:12 PM
3rick35c's Avatar
Under Construction
how many of these should i buy for my car to install the test pipes?
http://www.kingmotorsports.com/p-136...liminator.aspx
Old Oct 6, 2010 | 01:23 PM
two
Old Oct 6, 2010 | 01:39 PM
3rick35c's Avatar
Under Construction
I heard that an L-shape version is REQ due to the tight space. like this one... but do you think i can get away buying just 1 L-shape and 1 straight? or is it both side are really tight spaced that i need both sides to fit?
Old Oct 6, 2010 | 02:16 PM
why dont you go under your car with a tape measure and find out for sure?
Old Oct 6, 2010 | 09:13 PM
dcryan90's Avatar
mine fit very cleanly i mean it is pretty darn close to not fitting but it does you just cant use the 02 socket on it like before
suby01
V36 DIY
35
Jan 9, 2019 08:55 AM
mrwong@statik
Exhaust-Vendor
208
Oct 23, 2013 10:35 PM
sikkstreets
Archived Sales
May 10, 2009 09:50 PM
The Stimulation
Archived Sales
19
May 5, 2009 02:10 AM
4drmadness
Intake & Exhaust
14
Feb 7, 2009 02:53 PM
