G35 & G37, Coupes & Sedans
Check your 3rd brake light!
Old Nov 16, 2010 | 06:40 AM
NFSP G35's Avatar
? = 2B || !2B
It may very well be out, or only working part of the time.
There is an existing thread on this subject here and I also created a thread in the Sedan section here: https://g35driver.com/forums/g35-sed...yours-out.html
After a while, a few coupe drivers noticed it is a problem on the spoilerless coupes as well, so a thread was made here: https://g35driver.com/forums/g35-cou...t-failure.html
It seems that a common problem with the spoilerless G35 Coupe and Sedan is that the third brake light (the one in the back glass) either does not work, or works intermittently.
Apparently, Infiniti is either unaware of this problem, or (more likely) trying to brush it under the rug.
Several members have reported that informing Infiniti of the issue has done little good, so a better option would be to report the problem to the National Highway Traffic Safety Administration (NHTSA) and report the problem to them.
If enough people report the same problem, NHTSA will launch an inquiry which will hopefully result in greater attention from Nissan/Infiniti in this matter, and possibly a recall.
Clearly, NHTSA will be very interested in this information because of the obvious safety implications of a non working brake light.
NHTSA can be reached by phone at 1-888-327-4236
Also a complaint form can be filled out here: https://www-odi.nhtsa.dot.gov/ivoq/
The form is easy to fill out and only takes about 5 mins.
Members that have already sent in a report via the online form:
1) thescreensavers
2) Enochian
3) Wannabe6MT
4) Mustang5L5
5) NFSP G35
6) OKStateG35
7) fobizzle
8) heph
9) Junkyardspecial
10) nazc0
11) incubus3612
12) D10 04G
13) G35Papa
14) Lowerd4lyfe
15) G35Luv
16) VstyLe09
17) ntoxtiger
18) G35SedanGrn
19) XDR-V35
20) 19kdrill
21) 054DRG35
22) DG Steelo
23) petro2342
24) afr0puff ('03 Coupe)
25) NYYBaseball423
26) khull26
27) vq35dedriver
28) kday (G Coupe)
29) G35 Owner ('04 Sedan)
30) jonesmeister11
31) G_VQ3577
32) Antoniog35
33) Drift King
34) fjterry
35) O4G35DPM
36) DrewskiLe
37) dcsaggiesarge
38) evosmudge
39) vladkalika[/quote]
40) g35kid00
41) Wrathernaut
42) xRayZx
43) ktownlobo
44) 40fortpa
45) G35_FTMFW
46) EnerOnE
47) NAT@FFTec
48) TRN
49) FlyingLumpia
50) Indyjrt
51) pyropro
Old Nov 16, 2010 | 01:41 PM
kday's Avatar
There is more info on the subject from the original thread
Old Nov 17, 2010 | 01:37 PM
djfarhan's Avatar
is this applicable for the 2nd gen sedans as well?
Old Nov 17, 2010 | 01:38 PM
richardcvan's Avatar
i dont even notice.. let me check if my 3rd brake light is working
djfarhan's Avatar
i just installed my spoiler and checked my 3rd light to see if they hooked it up properly without taking that out and they both work...
Old Nov 17, 2010 | 02:00 PM
saywat?'s Avatar
so its not an easy fix or something?
Old Nov 18, 2010 | 02:39 AM
jonesmeister11's Avatar
"My 2003 Infiniti G35 coupe 3rd brake light is out (inside glass). This is a common issue with the G35. It needs to be brought to Nissan of America's attention. This could possibly cause an accident. I have seen that 28 people have filed a complaint to you on my car forum. But I feel that this issue needs to be addressed ASAP. If it were just one car with the issue then I would gladly pay for it, but since this is a common issue, Nissan of America needs to fix this as it was a production issue."
made complaint
Old Nov 18, 2010 | 09:18 AM
NFSP G35's Avatar
? = 2B || !2B
Members that have sent in a report to NHTSA:
1) thescreensavers
2) Enochian
3) Wannabe6MT
4) Mustang5L5
5) NFSP G35
6) OKStateG35
7) fobizzle
8) heph
9) Junkyardspecial
10) nazc0
11) incubus3612
12) D10 04G
13) G35Papa
14) Lowerd4lyfe
15) G35Luv
16) VstyLe09
17) ntoxtiger
18) G35SedanGrn
19) XDR-V35
20) 19kdrill
21) 054DRG35
22) DG Steelo
23) petro2342
25) NYYBaseball423
26) khull26
27) vq35dedriver
28) kday (G Coupe)
30) jonesmeister11
Old Nov 18, 2010 | 10:25 AM
Dmattei32's Avatar
subscribing.. i'll fill the form out later mine in the rear glass is out..
Old Nov 18, 2010 | 11:01 AM
NFSP G35's Avatar
? = 2B || !2B
^Ok, Just post up when you submit the form and I'll add you to the list
Old Nov 23, 2010 | 10:18 PM
marcinr's Avatar
20 Year Member
I just checked my middle brake light, and it was out, so I investigated. The light clips into the wiring harness with a plug that's right under the light and easily accessible when you open the trunk. That plug is flimsy and loose, and over time, it built up some oxidation on the contacts. I cleaned them off with a qtip moistened in WD40, and now they're shiny like new and the light works fine. This isn't a big deal.
Old Nov 23, 2010 | 10:31 PM
NFSP G35's Avatar
? = 2B || !2B
^I'll have to look into that.
Old Dec 3, 2010 | 07:17 PM
davidblak3's Avatar
Brakes
got my car back from the dealership today and they said the same thing about my third break light and sure enough it was out and i will look in the future to see if it cuts back on, but my side reflector lights on my tail lights are also out and i bought a brand new pair of jdm tail lights not sure if thats related or not. BTW I did file a complaint
Thanks,
Dave
Old Dec 3, 2010 | 08:00 PM
marcinr could you write up a DIY?
Old Dec 3, 2010 | 08:59 PM
the_sedan's Avatar
does this apply to those who have done the wingless swap and have no high mount?
