G35 & G37, Coupes & Sedans
How do you remove the stock shift knob on a 04-G35
Old Oct 24, 2011 | 11:48 AM
StL Stranger's Avatar
How do you remove the stock shift **** on a 04-G35
what is the easiest wat to remove the stock shift ****?? THANK YOU!!
Old Oct 24, 2011 | 01:40 PM
Mr. Samster's Avatar
on an automatic. You pull down the silver button piece. then push out the pin that holds the **** in place and that its
Old Oct 24, 2011 | 01:43 PM
I have a manual, is it the same way??? I hope it is.. because it sounds really easy
Old Oct 24, 2011 | 02:17 PM
umm... as for a manual... i have no clue lol. But im assuming it should be something along that route. probably just unscrew it. For the automatic we have a button that we need to push so that is why we need to take the pin out to remove the ****.
Old Oct 24, 2011 | 02:22 PM
well the reason im concert about this is because i read it somewhere to be careful how to unscrew or how i pull off the shift **** or i can mess something up.... i mean on my old cars it was pretty simple like u said all i did was unscrew it and pull it off, but i dont wanna do that to my g35 i want to hear from ppl that already done it lol
Old Oct 24, 2011 | 03:13 PM
Aku's Avatar
Aku
It just unscrews. Really easy mode
Old Oct 24, 2011 | 03:27 PM
faiz23's Avatar
Be careful when you just try to unscrew. There is a proper method to break the loctite loose that is applied from factory. The transmission is direct linkage and the pivotball is a weak point in the transmission. When you try to unscrew and apply torque the shifter starts to tweak and flex. The proper method is using a crescent wrench / strap wrench on the shift **** and get underneath the shift boot cover and use a vise grip pliers to hold the shifter straight so you do not torque it when you try to take the shift **** off.
https://g35driver.com/forums/1837462-post1.html
FSM
http://my350z.com/forum/3115540-post32.html
Old Oct 24, 2011 | 03:45 PM
Xet's Avatar
Xet
VERY WRONG! You can cause a lot of damage approaching it this way.
Follow the guide the other person posted, make sure to wrap the clamps/pliers/w.e with towels or else it will mar your ****. First time might be pretty tough to get off due to the glue on the threads.
Old Oct 24, 2011 | 07:59 PM
magic5g's Avatar
Make sure you grip the bottom HARD with a vice with towels so it doesn't turn when you unscrew the shift ****. If you rotate the bottom piece, you will fck up your transmission.
Old Oct 25, 2011 | 05:21 AM
O.G35's Avatar
^ +1 . mine was difficult, just make sure you keep it straight as possible.
Old Oct 25, 2011 | 08:59 AM
Aku's Avatar
Aku
My bad, I bought the car used off my brother and he had already removed it a few times so by then the thread locker wasn't very tight and just unscrewing it took barely any effort.
Old Oct 25, 2011 | 09:10 AM
EL-EE-ES's Avatar
follow this diy
https://g35driver.com/forums/body-in...lled-pics.html
Old Oct 25, 2011 | 12:03 PM
BjkearG35's Avatar
Follow the guide
Mine took two people to get off it was on pretty good. I held the shifter straight with a pair of vice grips and a buddy of mine unscrewed it with another set of grips. Only took about 15-20 minutes but I would make sure not to be moving and jerking the shifter back and forth.
Old Oct 25, 2011 | 12:54 PM
Thanks everyone for the help
jsimonk
Dec 22, 2023 03:49 PM
JG_G35
Accessories
Feb 25, 2016 01:44 AM
G35fromPA
Interior
21
Sep 20, 2015 08:58 AM
z_spec
West
Aug 13, 2015 07:38 PM
nervseele
Jul 17, 2015 11:21 PM
