G35 & G37, Coupes & Sedans
Recommended Maintenance: Buying a Used g35
Old Mar 17, 2012 | 10:13 AM
snowtrax's Avatar
When you buy a used g35 and you aren't sure if all of the maintenance has been done, the following things can be performed with some mechanical inclination and minimal tools. The total cost will probably be near $200 if done at home. I've listed the services from what I believe to be the most important to those of lesser importance.
Engine Oil (and filter)
Air Filter
Drive Belts (2)
Automatic Transmission Fluid (2 or more times if dirty)
Rear Differential Fluid
Front Differential (AWD only)
Transfer Case Fluid (AWD only)
Spark Plugs (if start-up is often rough)
Power Steering Fluid
Coolant
Brake Fluid (if dirty...often this is done during a brake job)
Cabin Air Filter
If I missed anything, please feel free to add! Also, I would only recommend using Nissan fluids for the transmission, differentials and transfer case.
Old Mar 18, 2012 | 08:34 AM
flyz's Avatar
Good list.
When I got my coupe last year @ 67.5k miles, I did everything except the belts, coolant and brakes. Then my rad decided to crack a couple weeks ago so did that as well.
New brakes + ss lines in a few weeks. Cabin air filter next oil change.
Old Mar 18, 2012 | 05:03 PM
dvandriesen's Avatar
In the same process of doing this list. Got the car with 61k just got new coolant, tranny fluid,rear diff fluid just have to get this thing up on stands and crack at it.
Old Mar 19, 2012 | 05:50 PM
Tony.G35's Avatar
I purchased my '05 6MT Sedan 1 month ago with 74,400 miles and I really need to get on this list! I'm going to hit 75,000 today on my way home from work. The car is in very good shape, but I don't know anything about the maintenance so I guess to be safe I need to knock this stuff out. With 2 kids both under 3 years old I may end up taking it to a dealer, but they quoted me $680 to do the 60k service. Ugh!
I'm going back to the last "major service" which was 60k miles.
In addition to the list you started, the manual also recommends the following:
- Replace radiator cap (I plan to do this with the increased pressure one)
- Replace radiator hoses (I plan to do this with silicone hoses)
Minor things that can probably be done as needed:
- Lube all locks/hinges
- replace wiper blades
- rotate tires
And of course Inspect a bunch of stuff:
- all lights
- axle & suspension parts
- brake lines/cables/calipers/pads/rotors
- drive shaft boots
- exhaust system
- front suspension ball joints
- fuel lines/connections
- fuel tank vapor vent system hoses
- headlights- adjust if necessary
- propeller shaft (AWD)
- steering gear & linkage and ball joints
I think you covered the major stuff that is more important, but in case anyone wants to be very thorough I figured I'd put all the details out there.
Old Mar 19, 2012 | 10:47 PM
AARONHL's Avatar
Stick this thread up there
Old Mar 30, 2012 | 09:48 PM
J-NaDa's Avatar
Great list. Maybe link to some DIY threads? If you're trying to get it stickied, that certainly couldn't hurt.
Old Apr 29, 2012 | 09:07 PM
snowtrax's Avatar
Please use this thread! People seem to be wondering things that this would answer.
Old Apr 29, 2012 | 10:41 PM
gary c's Avatar
Before you post a thread you really need to do a ....... SEARCH, this exact list was posted less than a year ago. I believe no question is stupid but how many times are you going to ask it? I haven't answered a thread like this for a long time but this is really ridiculous! If you can post a thread you can use our SEARCH function....Gary
Old Apr 30, 2012 | 08:08 AM
snowtrax's Avatar
People seem to post questions asking about this weekly so hopefully this list for dummies will prevent some of those people asking the same thing over and over again because people obviously weren't using the other one.
Old Apr 30, 2012 | 09:20 AM
gary c's Avatar
What makes you think making a "Repost" will change anything? Most won't SEARCH and the other percentage won't understand WTFs on the list....Gary
Old Apr 30, 2012 | 09:33 AM
aaron3719's Avatar
Do any of you trust the dealers checking all this stuff out when changing your oil? I always get this feeling that they like to make **** up to make you fix it.
Old Apr 30, 2012 | 11:48 AM
That's G's Avatar
What a pessimist, bro. If this isn't useful to you, then don't use it. It's that simple.
On another note, I agreed with who ever requested DIY links under each bullet point if this is going to be stickied. I think it would be a useful sticky, though.
Old May 6, 2012 | 10:43 PM
916TownG35's Avatar
is gear oil considered as differential fluid?
Old May 6, 2012 | 10:58 PM
gary c's Avatar
Yes that's what they call it, check your owners manual for the correct weight. I suggest you use synthetic, either Red Line or AMSOIL both are high quality gear oils. I'm swapping mine out this week while I install my ART pipes....Gary
Old May 7, 2012 | 12:19 AM
herrschaft's Avatar
Even more simple: http://x.infinitihelp.com/forum/maintenance.php.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
Karnicle
Jul 23, 2015 05:08 AM
