G35 & G37, Coupes & Sedans
Old Oct 12, 2014 | 11:46 AM
  #2806
Cesar95's Avatar
Since its been raining all weekend and still is, ill be cleaning the leather and vacuuming the inside
Old Oct 12, 2014 | 02:40 PM
  #2807
ScraggleRock's Avatar
Originally Posted by SAMzG35
How often do you change differential oil?
Mine got 65ish k miles and not sure when it was last change if ever.
A lot of people do theirs at around 40-50k. Let's just say mine was well beyond that. It wasn't very dirty tho. I was somehow missing some tho. It should take around 5.5 QTS between the tranny and diff, but I only took 4 QTS to the recycler, and I have no leaks.. Hmm..
Shifts and coasts like a dream now tho. Definitely recommend.
Old Oct 12, 2014 | 08:23 PM
  #2808
Mustang5L5's Avatar
I did:
Replace both hood hinges
Replace both HID bulbs (one blew)
Replace PCV
Oil change/filter
Trans fluid drain/fill
Install new washer fluid cap (old one got brittle and fell off)
air filter
cabin filter
Bleed all 4 brakes
Relube all caliper slide pins.
Was going to replace my rear shocks, but ran out of daylight. Another day.
Old Oct 12, 2014 | 10:38 PM
  #2809
Conissah's Avatar
Changed the oil and oil filter. RP 5w-30 and found out that the oil drain bolt has been replaced with one of those quick drain valve things. Super easy to change. Am I supposed to take the oil filter out thru the hole in the splash tray, or do I have to take it off every time?
Old Oct 12, 2014 | 10:42 PM
  #2810
Urbanengineer's Avatar
It's up to you, I have an aftermarket under pan because I couldn't fit my hands into the oil door for as routinely as I changed oil.
Old Oct 12, 2014 | 11:19 PM
  #2811
Shawno72's Avatar
Saturday I installed a set of BC Coilovers. All I need now is to roll my rear fenders and get 30mm spacers out back and move my 25mm up front and I'll be more flush.
Old Oct 13, 2014 | 12:12 AM
  #2812
Shanes_G's Avatar
Starting to come together!
Old Oct 13, 2014 | 12:13 AM
  #2813
Shawno72's Avatar
Thanks Shane. Now I just need someone local to roll my fenders
Old Oct 13, 2014 | 10:46 PM
  #2814
andy_cliff's Avatar
Not so much what I did on the G, but what I bought for it.
Motordyne Mrev2 Lower plenum
Motordyne 5/16 thermo spacer
350z engine cover
= $300 NZD ($236USD)
DOMO
Old Oct 13, 2014 | 11:03 PM
  #2815
Shawno72's Avatar
Got the rear fenders rolled so I can push the wheels a little further out
Old Oct 13, 2014 | 11:06 PM
  #2816
Lartytiejdke3's Avatar
Originally Posted by andy_cliff
Not so much what I did on the G, but what I bought for it. Motordyne Mrev2 Lower plenum Motordyne 5/16 thermo spacer 350z engine cover = $300 NZD ($236USD)
for all 3??
Nice!
Old Oct 13, 2014 | 11:18 PM
  #2817
andy_cliff's Avatar
for all 3??
Nice!
Yes sir
Old Oct 14, 2014 | 07:58 AM
  #2818
HotRodG35's Avatar
Changed Oil
Picked up a 6MT VLSD Differential to complete my DIY 5AT to 6MT conversion.
Bushings removed (will be installing Poly Bushings)
Casing sand blasted
Casting marks grounded down
Sent off for powder coating
Old Oct 14, 2014 | 09:29 PM
  #2819
Wash, wax, headlight polish, polished all the black stuff (front honeycomb, windshield wipers, window mouldings, roof rails, sideview mirror mounts, sunroof moulding).
Man, I need that nismo bumper. This 04 thang is starting to look dated.
Old Oct 14, 2014 | 09:37 PM
  #2820
I think I'd rather see you with a sport bumper
